front break pad change
Old 10-29-09, 04:53 PM
97CE LS400
97CE LS400's Avatar
Default front break pad change
I was looking at the tutorial lexls for front break pad replacement. Will this procedure apply to my 97 or is the break system different for the 90-94 model they demonstrate?
Thanks
Old 10-29-09, 05:15 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
its different.
look in the ucf20 faq.
Old 10-29-09, 07:05 PM
97CE LS400
97CE LS400's Avatar
Thanks PD...so looking at the tutorial, I have to remove the 2 bolts holding the caliper..remove sensor....remove caliper to get access to the pads>>>>remove clip & pins>>>>remove old pads>>>insert new pads.
Thanks again
Old 10-29-09, 07:43 PM
PureDrifter
BahHumBug
thats only if you're changing the rotor.
otherwise i's remove spring clip, big flat spring retainer, 2 pins, pads, push pistons back, insert pads, go in reverse.
Old 10-30-09, 10:31 AM
97CE LS400
97CE LS400's Avatar
Thanks
Old 10-30-09, 11:17 AM
JimsGX
JimsGX's Avatar
And grease the sliders...
Old 10-30-09, 02:34 PM
97CE LS400
97CE LS400's Avatar
Sliders??
Where is that on the diagram?
Thanks
Old 10-30-09, 03:08 PM
PureDrifter
BahHumBug
c'mon Jim, '95-97 arent a floating piston caliper, its an opposed 4piston
Old 10-30-09, 04:16 PM
JimsGX
JimsGX's Avatar
Ooops!! Nevermind!
Old 11-02-09, 09:44 PM
97CE LS400
97CE LS400's Avatar
just bought OEM pads will put in this weekend. Is the use of brake quiet needed on the shims or is it optional?
Old 11-03-09, 09:34 AM
McSwine
McSwine's Avatar
I would use it. I've seen it at the auto parts stores up by the cash register in a little foil packet for a buck or two...no need to buy a ton of it.
Old 11-03-09, 11:55 AM
PureDrifter
BahHumBug
use it, they squeak a bit if you dont.
GibbsLexus
RX - 3rd Gen (2010-2015)
11-21-17 07:37 AM
silkx3
Suspension and Brakes
03-06-16 07:05 PM
jpw
01-27-13 08:13 AM
myztikal47
01-18-06 10:15 AM
933005spd
SC- 1st Gen (1992-2000)
06-04-01 06:55 AM
Quick Reply: front break pad change
