Turn signal lens coming loose ('99 LS400)
Old 10-16-09, 01:04 PM
dantampa
dantampa's Avatar
Default Turn signal lens coming loose ('99 LS400)
Hello all,
I have a '99 LS400 and the right lower turn signal lens comes loose every time I drive. When I get out, I can easily "press" the turn signal lens right back into place. My question is, where is the screw/clip, etc that I need to tighten to keep the lens in place?
Thanks,
Dan
Last edited by dantampa; 10-16-09 at 01:05 PM. Reason: Removed two redundant pictures
Old 10-16-09, 01:48 PM
Kansas
Kansas's Avatar
It's a dummy light housing and not a turn signal -- it doesn't contain a bulb. On Japanese home market cars the housing is much deeper so it can hold a bulb for a corning light.
This little dummy light housing is held in place by the one screw you can see and a friction fitting -- the housing should snap into place via the friction fitting so maybe something is broken. Remove the one screw and pry out the housing -- I've used a stiff blade putty knive to pry them out on my car.
Swint
06-13-17 09:58 AM
Dart562
15
06-02-15 12:16 PM
dannymagoo
03-19-10 06:11 PM
celsiorlee
06-15-09 08:09 AM
Quick Reply: Turn signal lens coming loose ('99 LS400)
