Cold start problem - low idle.
Old 10-08-09, 11:28 AM
Och
Och's Avatar
Default Cold start problem - low idle.
Whats up guys, this problem just started yesterday. When I start the car, idle stays low, pretty much at 650rpm - which is the normal speed for when the engine is warm. It of course makes for a rather rough/vibrating idle until the car warms up. When it warms up, the car is perfectly normal, idle doesn't drop below 650, everything is nice and smooth.
So what could it be? I have a few theories.
1) ECT Sensor - it could be broken and telling the computer that the engine is warm, and therefor the computer isn't sending enough fuel. But I kind of rule that out, because that would create problems on acceleration while the engine hasn't reached operating temperature. Plus, on a cold start the exhaust has a heavy gas smell, so I'm more inclined to think that it isn't getting enough air.
2) Cold start injector - I really don't know how it works and whats its function. Can somebody shed some light onto that?
3) Idle Air Valve - thats my most likely suspicion. Could it be that its not opening and the engine isn't getting enough air? But in that case, wouldn't I still have a problem once the engine is warm?
Old 10-08-09, 12:39 PM
3UZFTE
3UZFTE's Avatar
Hey there Och, I will help you to try to come up with some answers instead of bring in this one in. Sorry for asking, but what year do you have? I ask because it will help me diagnose a little easier, as a 89'-92' 1UZ uses the Cold start injector, and the 93'+ doesn't. That being said, this is more for the pre-92'. 94' and later, just ignore the cold injector part. Does the vehicle drive fine even during a cold start or is it a little sluggish? Once the vehicle is warmed up, start it back up and note what it does. Is it a cold engine running thing (start up, idle, driving, etc.) or is it just during idle? I think as far as the theories go, your there, however I would like to add that the ECU controls all those things, so if you have an issue that can always a likely candidate. 1st rule of diagnosis, don't rule anything out. Here is a normal cold start sequence. As you turn the key, the computer takes a snap shot of the sensors to get an estimate of what the operating conditions are and should automatically start up in cold start, which is an electronic high idle. This is achieved through the ECU controlling the idle air control valve, fuel, and sensors. During cold start the engine idles fast (1000+rpm) because it is running rich in order to warm up sooner to achieve operating temperature quicker, it is basically running off of pre-programmed memory. The 8 fuel injectors, I do believe, do not add the extra volume, but the cold start injector does. Once the engine reaches operating temp it shuts the cold start injector off in order to resume warm idle, which is around 650rpm. Once the ecu idles the engine down, it is then in closed loop, which means it is reading from the temp sensor, O2 sensors, and all the other various ones that monitor all the things like fuel strategy, accessory loads, etc, etc. That being said.......
1) Well this could be true, but typically if the sensor breaks it normally fails to it's default, which is -30 or something. How new is the sensor? Try unplugging the sensor to see if you get a different result. Measure the resistance of the sensor, Ohm it.
2) This is what I am leaning towards, however I am not sure how to test it. However you can either clean it with some solvent or you could source one from another junked LS4. If it's a 93 or later, you don't have one, and you will need to start looking for another solution.
3) Obviously controls the idle, and like you said it works, just not during the cold start. Normally air is never a problem as naturally aspirated motors suck, literally suck air to stay running. If you don't think if getting enough air, take the hose from the MAF tubing to the IAC (idle air control) valve off, and put your thumb over it quickly, like your plugging the IAC valve up, it will suck you thumb in, and the motor should stop as it is not able to suck any air in to burn. Try taking the IAC off and cleaning it with some break cleaner, it's simply it's just a few clamps and 2 bolts.
I hope I helped a little bit..... Let me know if I need to clear anything up.
Old 10-08-09, 02:55 PM
Och
Och's Avatar
Those are pretty good tips. My car is a 94, so I guess then cold start injector is ruled out.
The card drives just fine when its cold or warm, its just that cold idle is low. If I tap the gas to raise RPMs to around 1400, like it should be on a cold start and hold the pedal there, it keeps running just fine, and drives fine as well.
The first thing I'll do is test the IAC the way you described, I don't know why I didn't think of it myself. Thanks!
Old 10-09-09, 04:00 PM
Amskeptic
Amskeptic's Avatar
Cold start injector is only responsible for getting the engine started. As a general rule, they are wired only to energize during cranking. Immediately after start, with the key released, the water and air temperature sensors are responsible for fuel mixture, and the idle air valve is soley responsible for the idle rpm through the warm up phase. You need to distinguish between a functional valve that is not getting orders versus a non-functional valve that is.
Colin
Old 10-09-09, 08:02 PM
gmacrae
gmacrae's Avatar
Im thinking IAC also. Drown it in brake cleaner like he said. There's also a great CRC product i've used for this kinda stuff called Carburettor Cleaner. It doesnt evaporate as quick as brake cleaner does.
I remember you mentioning you're running a straight vac hose in place of your removed P/S idle up valve. Pointless IMO, but you can use it to see if the IAC is actually moving (squash it to block it and see if the IAC adjusts itself to keep the idle the same). Infact that hose could be the only reason the engine is running if the IAC is stuck completely closed.
Old 10-09-09, 09:38 PM
Och
Och's Avatar
Well, the problem decided to fix itself today. If it comes back, I'll figure out.
Old 01-26-11, 12:55 PM
95redsc400
95redsc400's Avatar
Default the missing cold start injector
I don't know if it helped him, but it helped me. I have a 95 sc400 that I am putting a JDM engine into. The work shop manual shows a "cold start injector" mounted to the bottom side of the air intake chamber. My old AIC showed no signs of anything being mounted there, nor did the JDM engine. It has been months since pulling the engine, due to weather, gasket matching, and light porting and polishing on everything to do with intake and exhaust. I thought maybe I had lost the little b%^&^!.
Oh yeah, the original engine was mistreated. Right head gasket was blown and they evidently kept running this fine car, melting on the bottom 2 pistons on the right bank. Sorry, but I had to cry on someone's shoulders!
rcunamay (03-25-20)
stvwssll
01-25-19 10:38 AM
wan8dan
09-17-14 07:46 PM
Qcollons
11-08-11 04:02 PM
DKKis350
01-23-11 11:08 AM
fgerwe
12-02-07 09:17 PM
Quick Reply: Cold start problem - low idle.
