Starter Replacement Q's
Old 10-07-09, 02:27 PM
dave_id
dave_id's Avatar
Default Starter Replacement Q's
I will be under taking this wonderful process and I am curious if I should re use the gaskets or purchase new ones? And if anybody knows which gaskets to get, part numbers, etc, blah blah blah, then please share
Thank you
Old 10-07-09, 03:14 PM
AzHotLS
AzHotLS's Avatar
get new ones.
gotta know the year before part numbers can be given.
Old 10-07-09, 04:36 PM
curepunx
curepunx's Avatar
+1 on getting new gaskets - usually available at your local major auto parts store.
Give us the year and we'll try to help on the next step.
Old 10-07-09, 11:33 PM
stevechumo
stevechumo's Avatar
The hardest part in the process is to take out the 2 bolts that hold the starter to the block. Drink plenty of water before the job, because you'll sweat and swear a lot. LOL. Aftermarket gaskets are cheap, such as Felpro.
Old 10-07-09, 11:35 PM
genetic
genetic's Avatar
Prepare to get frustrated
shouldn't be too bad, good luck!
Old 10-07-09, 11:50 PM
LiCelsior
Retired
LiCelsior's Avatar
you need the rear coolant bypass gasket, intake manifold gaskets, and the upper plenum gaskets...oh and throttle body and IACV gaskets.
gd3tyrone
12-03-13 11:32 AM
killsnake
33
03-21-13 05:01 AM
Bradster
05-13-10 06:38 AM
400DGRZ
Maintenance
14
01-19-06 09:44 PM
leosls400
03-09-05 02:32 PM
Quick Reply: Starter Replacement Q's
