This Forum is Sponsored By:
Go Back   Club Lexus Forums > Lexus Model Forums > LS Models > LS400
Thread Tools Display Modes
Old 10-04-09, 04:03 PM   #1
Lexus1994
Trader Score: (0)
Unhappy 1994 LS400 Heater not working - Need Help
I just purchased a 1994 LS400 with the heater not working. The air blows, but no hot air. Help would be very much appreciated. Thanks for your time.
I do not have owners manuel so I'm having to guess where everything is at the moment.
Lexus1994 is offline   Reply With Quote
Old 10-04-09, 05:41 PM   #2
AzHotLS
Trader Score: (0)
AzHotLS's Avatar
Welcome to the forum.
The first thing I would check is the heater valve under the hood, see post 5 in this thread:
http://www.clublexus.com/forums/ls40...r-problem.html
__________________
95 LS400 Pearl White
90 LS400 Pearl White R.I.P. 11/2008
AzHotLS is offline   Reply With Quote
Old 10-12-09, 11:48 AM   #3
tmahan
Trader Score: (0)
I had the same problem.
Run the car and turn the AC to max. Kil the engin and look at the heater control valve under the hood on the firewall. It should be all the way down.
Get back in the car start it up and turn the heat on full. Now go look at the valve, it should be all the way up.
If not look under the dash on the drivers side near the hump in the middle and
there is a black motor about 2" square with the cable attached on the inside.
Mine was broken.
I replaced it with a piece of coat hanger and it is working great.
tmahan is offline   Reply With Quote
Old 10-12-09, 02:31 PM   #4
Lexus1994
Trader Score: (0)
Thank you azhot and tmahan.
That is definately part of the problem. The cable is not working. I aslo added and bled the coolant. I think that was part of the problem as well.
tmahan,
The cable is not moving. How did you get to it to replace it. I see the black box and there are some white plastic arms connected to it that move when I change the temperature. But I don't see where the cable connects.
Thanks for all you guys help.
Old 10-12-09, 02:41 PM   #5
TexFinn
Trader Score: (0)
Heater??? We don't need no stinkin' heaters here in TX.
Have you also checked the heater core? Maybe it is clogged, or even bypassed.
__________________
94 LS400
TexFinn is offline   Reply With Quote
Tags
04, 94, air, control, core, es400, forum, heat, heater, lexus, ls40, ls400, rx330, valve, working
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
