has anyone heard of this? (Autronic Standalone ECU)
Old 09-23-09, 08:07 PM
dsabc2867
dsabc2867's Avatar
Default has anyone heard of this? (Autronic Standalone ECU)
http://www.rocketrally.com/website/i...ath=39_177_199
has anyone heard of this product? if so will it work on a 92 ls400? Or better yet has anyone installed this product and what were the results of running this stand alone system?
Old 09-23-09, 08:51 PM
BLKonBLK98
BLKonBLK98's Avatar
stand alones are usually reserved for extremely advanced tuning/swaps. if you have to ask it's probably not for you.
Old 09-23-09, 09:24 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
seconded .
Old 09-23-09, 09:41 PM
LiCelsior
Retired
LiCelsior's Avatar
thirdededed.
Old 09-24-09, 09:32 AM
avalon42
avalon42's Avatar
http://www.electromotive-inc.com/products/tec3.html
I used to be running one of these on my Z32TT. Definitely not for running anything near stock.
Old 09-24-09, 06:51 PM
dsabc2867
dsabc2867's Avatar
Default then...
then at what point is something like this good to install?
Old 09-24-09, 07:17 PM
avalon42
avalon42's Avatar
When you are twin charged and running a distributor-less setup on your LS400...
Old 09-25-09, 01:23 AM
dsabc2867
dsabc2867's Avatar
so the stock ecu would be able to handle any mods that are put in with the exception of FI?
Old 09-25-09, 08:07 PM
avalon42
avalon42's Avatar
Depends on the application. You haven't mentioned what you plan on doing to the car to warrant the standalone being needed.
You could always get the standalone, program it for running a completely stock configuration, but wth for? You have to pay for the dyno, and tune, and cost of unit + installation. Doesn't make sense but if that floats your boat to burn money, go for it.
Old 10-01-09, 08:59 PM
dsabc2867
dsabc2867's Avatar
so then tell me this what mods can i do that would not affect the settings of the factory ecu? thanks for your responses and advice.
Old 10-01-09, 09:03 PM
PureDrifter
BahHumBug
intake, exhaust, MAINTENANCE!
most ls400's arent properly maintained.
Old 10-01-09, 09:51 PM
avalon42
avalon42's Avatar
Search is your friend. You need to do a lot of reading, but you can do a s/c at 6lbs of boost that will work with factory limitations, albeit you should get an upgraded fuel pump.
Ditto on what PD said. Get your maintenance done first before spending a fortune on stuff that will blow it up faster.
Old 10-02-09, 08:05 PM
dsabc2867
dsabc2867's Avatar
thanks for all the advice guys. reading is really something i have time for. i really wish that i had the time to do alot of research but i work alot and rarely get on the net. thanks again. this forum has always been a big help
jawsaw1
06-24-15 01:34 PM
LANcr3w
66
10-28-13 11:01 PM
BigJohnLs
CL of Southern California
09-19-11 04:10 PM
Quick Reply: has anyone heard of this? (Autronic Standalone ECU)
