Pls Help Trouble code 22
Old 09-14-09, 06:14 PM
samoanboy
samoanboy's Avatar
Question Pls Help Trouble code 22
I've recently been having problems with my '92 LS400. A little history first: 97k miles, Always had problems with overheating, probably put more engine coolant than gas! air suspension has been known to not pump up and leave me stranded wherever. But other than that I love this lexus and it has gotten me to and from work for 3+ years.
Recently however the speedometer and rpm's dont work. But more importantly the check engine and trac off light will come on and when i attempt to accelerate say through a traffic light, the car will shutoff and not start back up leaving me helpless in a busy intersection. I pull the car over call for help and by the time it arrives the vehicle will start up again. The Idle will be all over the place and sometimes after stopping at a stop sign I wont even have to push the gas, the car will accelerate and sometimes i have to barely touch the gas in fear that if I gun it, it will die again.
I took it to the stealership and 15mins later received a call that it was my alterator and p/s pump was leaking all over it. So i replaced the alternator and rebuilt the p/s pump and guess what? exact same problem.
I cleaned out the throttle body, checked wires and harness's my ect sensor tested good once and bad once but havent replaced that yet.
Running a diagnosis with the tdcl under the steering wheel gave me trouble code 22 ect sensor circuit and my o/d off light blinked code 42 which i believe is vehicle speed sensor circuit.
I know i cannot trust the dealership, they took me for my $100 diagnosis and kicked me out the door with a bogey analysis.
Please help I know you CL members are the best!!!
festols400
11-22-11 08:39 AM
dtan1691
Performance
02-15-11 06:46 PM
samoanboy
Maintenance
09-15-09 07:19 PM
scshinobi
Performance & Maintenance
03-30-08 06:30 PM
ed0250
RX - 1st Gen (1999-2003)
07-24-07 09:42 PM
Quick Reply: Pls Help Trouble code 22
