ABS and Trac light on...
Old 09-12-09, 07:24 PM
beedyb220
beedyb220's Avatar
Default ABS and Trac light on...
Hello,
I just had my factory air suspension changed out to Megan coilover. Everything seems to be working fine except my ABS and Trac OFF lights do not turn off. Has anyone encountered this?
Bryan N.
Old 09-12-09, 09:17 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
sounds like you cut/installer cut an ABS wire..
Old 09-13-09, 09:52 AM
beedyb220
beedyb220's Avatar
Default ABS wire
Does anyone have a diagram that shows where the ABS wires are?
Old 09-13-09, 11:35 AM
hobojoe
hobojoe's Avatar
Hmmmm well seeing as I installed them i know i didnt cut any wires..... might have to go look for a pinched wire though.
Old 09-13-09, 07:59 PM
Li Ls4
Li Ls4's Avatar
is the front driver fender liner worn so that there is a hole where the all those taped up wires are.
it happened 2 me from the tire rubbing against it on every dip/bump. it started 2 strip the rubber isolation on the wires leaving the wire bare. and 1 of those wires was the wire to my abs which triggered the abs light.
i put electric tape over the bare wire and the light went away
Old 09-13-09, 08:57 PM
hobojoe
hobojoe's Avatar
No it was worn but not a whole he was still running factory 16" wheels.... lol the car was so low i had to have 2 people lift so i could slide a jack underneath the damn car.
Old 09-14-09, 01:10 AM
Max Power
Registered User
Max Power's Avatar
read the codes?
I'd try that first personally, to narrow it down.
Old 09-14-09, 04:08 PM
hobojoe
hobojoe's Avatar
ya hes outta town for the next week i think so its up to him now.....
Old 09-14-09, 10:07 PM
beedyb220
beedyb220's Avatar
Thanks guys... I'll take it to the Autozone to look at the codes when I get back in town.
samurai469
02-05-11 05:44 PM
Mv350
09-18-09 09:56 AM
Belement
Performance & Maintenance
03-22-09 12:29 AM
LMoney4o8
09-20-07 06:34 PM
Quick Reply: ABS and Trac light on...
