Power steering fluid?
I will be doing a full power steering flush this weekend, and I just wanted to clarify, exactly what type of fluid to use, for the 1st gen LS400.
I've seen people recommending Dexron 2, 3 and even 4 ATF fluid. Are they all the same?
Also, what is the difference between regular power steering fluid and Dexron ATF fluid?
If you are going to do a FULL flush(reservior, rack, lines etc), then that number may be close to correct. Never hurts to have extra if you need it. Can always use it for drain/fill on trans.
T-IV is available at a Toyota dealer for like 4.99 a quart. I was told that the total capacity of the PS system on a 1st Gen was 2.1 quarts. Why are 7 quarts needed to flush it?
I used Mobil1 Synthetic ATF for the PS. It states on the bottle that its Dexron compliant.
Lines and the torque converter.
