O2 sensors...universal or OEM?
Old 09-03-09, 08:18 AM
dann707
dann707's Avatar
Default O2 sensors...universal or OEM?
my check engine light just went on a couple of weeks ago and found out the code 25 which means i have to change my o2 sensors....my question is im on a tight budget so should i get universal ones of wait a little and buy oem ones...?
whats the difference....? im i suppose to replace all four of them..?
i have a 93 ls4 but the way....
Old 09-03-09, 08:37 AM
LiCelsior
Retired
LiCelsior's Avatar
www.oxygensensors.com
Old 09-03-09, 03:10 PM
python
python's Avatar
according to pure drifter its ok to use universal, im against it but i guess if its done correctly u can get away with it
Old 09-03-09, 08:41 PM
Max Power
Registered User
Max Power's Avatar
I was going to go with an NTK but it was nearly 120$ more than a universal.
I went universal. Working fine so far and my check engine light is now off.
As to how long it'll last, well who knows, but I wasn't willing to pay that much more for the same function at this time. (dropped a lot of cash on the car in the past week)
Old 09-04-09, 08:50 AM
damon
damon's Avatar
I paid $70.00 each (before Bing 10% Cashback) for Denso 234-4211 which is OEM. They click right into the existing harness so it was a DIY procedure for me.
This is the correct # for the "front", Pre-Cat Sensors. 94LS
Worked like a champ to because my CEL went out & I passed inspection with flying colors yesterday.
Old 09-04-09, 02:59 PM
3UZFTE
3UZFTE's Avatar
I bought universal ones for about $40 a piece, they work like a charm. If you are ok with cut the old harness plug off the old o2 sensor and solder it into the new sensor, you are good to go. If not, shell out the extra bucks for the fool-proof one.
Old 09-04-09, 07:35 PM
dann707
dann707's Avatar
So Damon did u get Yours froM the dealer..? And if so is that the part number...?
Old 09-04-09, 08:34 PM
JimsGX
JimsGX's Avatar
The number Damon provided is a direct fit. It has a plug on the end of it that plugs right into the vehicle. Denso makes a lot of OEM parts for Toyota/Lexus so they could very well be the original OEM. They're available all over the Internet, including Amazon.com...
http://autoparts.thecarconnection.co...-oxygen-sensor
Old 09-04-09, 10:22 PM
dann707
dann707's Avatar
ok kool thanks jimsgx im going to purchase them right now......
Old 09-05-09, 06:02 AM
Bradster
Bradster's Avatar
About 50 bucks each for Denso universal from Rockauto.com
Old 09-05-09, 10:04 AM
damon
damon's Avatar
The Denso site clains they are the oem for this part.
Old 09-05-09, 11:36 AM
haulin79
haulin79's Avatar
I am 99% sure Toyota does not make O2 Sensors, they just buy it from a supplier (like Denso) and then charge us double.
Old 09-07-09, 09:38 AM
3UZFTE
3UZFTE's Avatar
I'm also not 100% sure but I think Toyota actually owns part or shares of Nippondenso.
Old 09-07-09, 10:32 AM
haulin79
haulin79's Avatar
For sure. Toyota is one of the largest companies in the world, they probably own a large % of USA Inc.
Old 09-08-09, 12:33 PM
xyzzy_dude
xyzzy_dude's Avatar
Is it really necessary for these to be replaced? Mine's been throwing a P0161 code for a few weeks, which indicates that the heater circuit for the O2 sensor is bad, but the car is still running fine, and actually getting improved gas mileage? Besides OBD-2 inspection reasons, is there a reason these need to be working if the car is doing fine without them, so maybe I can wait until the inspection is due to get it fixed?
Mr1uz
SC- 1st Gen (1992-2000)
21
08-16-11 12:08 AM
blk99rx300
RX - 1st Gen (1999-2003)
19
11-04-08 07:15 AM
dunahoo
Performance & Maintenance
08-08-08 01:42 PM
deanbrown
04-30-08 08:12 PM
SC30096
11-14-07 11:39 AM
Quick Reply: O2 sensors...universal or OEM?
