My 93 LS400...
Old 08-28-09, 12:46 AM
  #31
Garage7RP
Garage7RP's Avatar
Smile continuation of wirings...
Run these wires and air lines under the carpet to the center console...
Set the struts' 36 way adjustable dampener to basic setting by first turning the adjustment ***** fully clockwise (you are now on the hardest setting), then adjust 2 full turns counter clockwise (about 12 clicks-you are now on basic setting). This will be your baseline setting. You may turn clockwise to hard and counter clockwise to soft depending on your preference and driving style and condition...
Double check all the wirings and connections. Once you have verified that everything is correct, you may start your car and let the compressors fill the tank. Once the tank is filled, fill the bags at approximately 80psi. Check each bags and fittings for leaks by using a spray bottle with soap and water solution. If you find any leaks, release the pressure and fix the leak properly. If there are no leaks, you may mount back the wheels and remove the car from the jack stands.
You may now start cleaning up your cluttered wiring by using those wire organizers and label each group as needed.
You have done a GREAT JOB!
Old 08-28-09, 12:49 AM
  #32
Max Power
Registered User
Max Power's Avatar
Lets see lets see!
Old 08-28-09, 01:01 AM
  #33
Garage7RP
Garage7RP's Avatar
Smile Now for the best part...
It is time for demonstration...
All up (approximately ~130psi)...
Old 08-28-09, 01:08 AM
  #34
Garage7RP
Garage7RP's Avatar
Cool demo continuation...
All down (0psi)...
Next will be to paint the car. Thank you!
Old 08-28-09, 01:30 AM
  #35
Max Power
Registered User
Max Power's Avatar
That's pretty sweet!
Still not sold on body kits in general but air suspensions are pretty cool.
Old 08-28-09, 02:19 AM
  #36
PureDrifter
BahHumBug
PureDrifter's Avatar
what's going to be your driving height?
Old 08-28-09, 05:15 AM
  #37
Li Ls4
Li Ls4's Avatar
car is comin along really good man
Old 08-28-09, 08:32 AM
  #38
Schnitz
Schnitz's Avatar
Awesome! Quite an introduction to your build.
Old 08-28-09, 08:56 AM
  #39
fourthmeal
fourthmeal's Avatar
Air Ride FTW, man. Beautiful.
Old 08-28-09, 09:11 AM
  #40
AristoPra
AristoPra's Avatar
Dayuuuum cousin! ! ! where was i when all this happened? ? ? you never call me up when it's time to do the cool stuff! ! ! always gotta surprise me! ! !
man, yerr ride has come a loooooong way and i'm soooooooo jealous! ! ! now we just have to wait for paint and yerr ride will be complete! ! !
Old 08-28-09, 11:09 AM
  #41
genetic
genetic's Avatar
This is the COOLEST UCF10 I have seen in a long time.
GOOD JOB. i knew it was going to be good from the start.
Old 08-28-09, 11:31 AM
  #42
Garage7RP
Garage7RP's Avatar
Wink To PureDrifter
This is my ride height. (F) ~70psi (R) ~50psi Dampening setting is basic...
The ride is comparable to stock.
Old 08-28-09, 11:35 AM
  #43
Garage7RP
Garage7RP's Avatar
Smile To AristoPra
You were probably surfing the net . I did the install piece by piece after work and sometimes I tell work if I can work at home certain days .
Thanks!
Old 08-28-09, 01:19 PM
  #44
I'mStock
I'mStock's Avatar
For real? I always hear people say that but I always wonder just how similar it is. It's one of the main reasons that I don't want to hurry up and buy coilovers just for ride height... I think a Lexus should ride like a Lexus.
Old 08-28-09, 01:57 PM
  #45
Garage7RP
Garage7RP's Avatar
Smile To I'mStock
Yes for reals!
Since the struts are 36 way adjustable, you can taylor the dampening to your liking.
With springs, they go by spring rates. The higher the rate the stiffer the ride. It is similar with air bags. The higher the air pressure the stiffer the ride will be too.
Quick Reply: My 93 LS400...
