Should I run Synthetic on next service?
Old 09-01-09, 09:55 PM
  #31
nthach
nthach's Avatar
Originally Posted by 3UZFTE
Oh man, I am sorry. $60 is just unheard of for a normal oil change... In fact if someone quoted me at $60 for conventional, I'd ask if they were joking.... Yeah, I don't blame you for saving a few bucks, holy smokes... $60!
If you think that's bad, $120 is the asking rate at the local Lexus dealer here, using Kendall oil.
For some reason now, both Toyota and Honda call a simple oil change a 5000 mile maintenance or A service: change oil and filter, rotate tires. I have Costco take care of that if I'm too lazy to drive down to the old job - rotating and balancing tires that is. I also should have said the local Honda dealer here is less than Toyota - $40 for a oil change, my neighbor gets free coupons once in a blue moon. The drive-thru shops charge $29 for bulk Pennzoil YB and a Purolator-made Pennzoil filter, with the exception of Jiffy Lube which is almost as bad as the dealer.
komobu
06-24-20 11:33 AM
HerMekanic
HS 250h Model (2010-2012)
15
10-02-10 12:50 PM
horent135
Maintenance
21
05-19-09 11:09 PM
mofogasm
12-16-05 11:41 AM
martialart
Maintenance
21
10-30-03 06:47 PM
Quick Reply: Should I run Synthetic on next service?
