2000 ls 400 exhaust leak and engine vibration
Old 08-22-09, 09:46 AM
lexusguy09
lexusguy09's Avatar
Default 2000 ls 400 exhaust leak and engine vibration
My 2000 ls 400 has developed an exhaust leak. It sounds like it could be the manifold gasket. Not that loud but it sounds like air being squeezed out of the gasket. Any ideas on a price to fix?
Also, the engine vibrates when pressing the gas in neutral or while accelerating. I am thinking it is one of the engine mounts. It is not smooth like this engine should be. Any help would be great.
Old 08-22-09, 11:41 AM
JimsGX
JimsGX's Avatar
I'd get the exhaust leak fixed first and see if the engine vibration is still there afterwards. The exhaust leak could very well be throwing off the signal to one of the oxygen sensors and causing the engine vibration/rough acceleration.
Old 08-22-09, 12:16 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
are you sure its a manifold gasket and not the infamous EGR leak?
Old 08-22-09, 06:10 PM
Lexscme
Lexscme's Avatar
you can try using window weld for the motor mounts itll keep them solid. My friend did that to his car,and no enigine vibration.
Did you check all the exhaust flanges and bolts to see if any are loose??
Old 08-23-09, 11:55 PM
skperformance
skperformance's Avatar
RUn some seafoam throught to find the leaks easily.
Old 08-24-09, 10:33 PM
JBrady
JBrady's Avatar
No EGR on the 98-00 models so that is not it. Not likely the manifold to head gasket. Probably the manifold to cat or cat to downpipe OR some damage. Hard to say on the vib as 98-00s do that (mild) under some conditions.
Old 08-25-09, 04:20 AM
PureDrifter
BahHumBug
wow i should read the thread title
Old 08-25-09, 06:17 PM
Lexozz
Lexozz's Avatar
Could be tranny mount. Have that checked as this will cause vibration when worn out.
mauipaul
01-18-15 08:26 PM
thaeleelyr
RX - 1st Gen (1999-2003)
01-16-13 05:21 PM
SEANCLIME
02-16-12 10:33 AM
lexusguy09
Maintenance
09-09-09 11:32 AM
Quick Reply: 2000 ls 400 exhaust leak and engine vibration
