99 LS Power Steering Fluid or ATF ?
Hey guys just looking for a little insight here. Getting ready to do a PS flush on my 99 LS which will include cleaning the solenoid screen.
My question is..
If I'm already spending the extra dollars to upgrade to synthetic (ATF) fluid anyway, why not use RedLine synthetic Power Steering fluid. Maybe these two fluids are basically the same and it is a mute point. I don't know. It just seems obvious to me to use a fluid that is designed for a power steering system and not a transmission. I've heard lifetime Toyota (dealer) mechanics say there are certain detergents in ATF that are hard on the seals of a PS system. That is really my main concern. I realize there is a lot of old school thinking vs modern day knowledge... Please help me fill in the gaps here, pros and cons, etc.
Thank you
My question is..
Thank you
Welcome to CL. I think ATF is just used in PS due to higher temp/pressure but I am not a mechanic. At any rate I too switched to Mobil1 Syn ATF for PS many years ago and have not had any leaks or other issues. Since I use Mobil1 SYN oil I thought I would swap to their ATF.
I don't know of Redline but don't see any reason why you couldn't use it Others are more mechanically inclined here - let's see what they say.
Redlineoil.com gives a very detailed overview of their PS fluid properties here:
http://www.redlineoil.com/product.aspx?pid=79&pcid=27
Thanks again!
Does anyone know what the total power steering fluid capacity is on the first gen LS? I've searched here, alldatadiy and lexls but can't find the capacity, just that it calls for dexron II/III...
Thanks
Thanks
BahHumBug
This is exactly the kind of message I was hoping for. An answer with some REASONS behind it. Thank you! Any chance you could elaborate just a little more?
Thanks again!
Thanks again!
for the transmission:
you need a fluid meeting the same requirements as Type T-IV, JWS 3309, GM 9986195 and Audi G-052-025-A2. all use the same type of aisin transmission and have the same fluid requirements.
http://www.mobil.com/USA-English/Lub...l_ATF_3309.asp
power steering:
you just need any fluid that meets the DexronIII/Mercon specs.
the redline PS fluid does, on your link:
RED LINE POWER STEERING FLUID satisfies the service fill requirements of most auto manufacturers and can be used where the manufacturer calls for any automatic transmission fluid such as Dexron®, Dexron II-D®, II-E®, or Dexron III®, Ford Type-F, Mercon, or M2C138-CJ such as required by Ford, AMC, Toyota, Nissan, Lexus, Infiniti, Jaguar, VW, Mercedes-Benz, BMW, SAAB, Subaru, Volvo, Porsche, Mitsubishi, Mazda, and many others.
