Flushing Brake Fluid
Old 08-07-09, 04:21 AM
GrayLS400
GrayLS400's Avatar
Default Flushing Brake Fluid
Two questions.
1. Can it be done without raising the car and taking off the wheels?
2. Which brand makes the best reasonably priced one-person hand pump powered bleeder for a 98 LS400?
Thanks.
Old 08-07-09, 08:31 AM
Nohawk Lex
Nohawk Lex's Avatar
Originally Posted by GrayLS400
Two questions.
Thanks.
I'm not sure if you can actually bleed the brakes easily on a car equipped with ABS since if you did it wrong, your ABS won't function. Pure Drifter, any comments?
Old 08-07-09, 02:31 PM
steveski
steveski's Avatar
I used to do it myself with wheels on - don't know about the pump though. These days I pay $25 (I bring fluid) and no issues with air in lines or with ABS.
Old 08-07-09, 04:31 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
bleed the brakes normally, i guess you could TRY to do it with the brakes on but i'm positive you won't have enough room without lifting the car up.
after you bleed all 4 corners you have to bleed the ABS pump.
05ls430518
01-26-18 05:27 AM
RoMiLex
04-22-14 08:24 PM
818GS
Suspension and Brakes
12-17-12 10:48 PM
98SBF
11-13-08 09:28 PM
erics3000
Maintenance
09-22-06 06:14 PM
Quick Reply: Flushing Brake Fluid
