Idle going up and down
Old 08-01-09, 12:31 AM
no1gsxr
no1gsxr's Avatar
Default Idle going up and down
Somebody help. My idle keeps going up and down. Even while driving. It started happening when i jump started my car cause the alternator is bad. Kept jumping it every 5 miles or so just to get it home.
Old 08-01-09, 02:01 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
look for vacuum leaks.
Old 08-01-09, 04:53 AM
onelove316
onelove316's Avatar
check main charging fuse to make sure you did not blow it, it will be the biggest fuse in your fuse panel under your hood and second you could have just shorted out a sensor from letting the power get to low it sounds like the idle air control valve more so than a vac leak because a vac leak would in most cases send the rpms really hi or very low sometimes it will go up and down but only really when you have a load on it and you are driving give those a check let me know
Old 08-02-09, 07:21 PM
no1gsxr
no1gsxr's Avatar
Thanks guys. I think it had something to do with the bad alternator cause when I changed the alternator everythng went back to normal. It scared the **** out of me cause i had alternators go bad a few times in my life but never effected the rpms.
flipnotize
10-07-14 09:15 AM
kevwats01
Performance
13
08-05-13 12:58 PM
tonyfazt
12-01-11 06:00 AM
czaredd
Performance & Maintenance
12-10-07 10:30 AM
AUGuy21
Performance
06-12-06 01:37 PM
Quick Reply: Idle going up and down
