98 ls400 w/NAV electronics dead
Old 07-19-09, 02:57 PM
concept98
concept98's Avatar
Default 98 ls400 w/NAV electronics dead
will start but all electonics are no show and can not change gear to drive. Wil not let me move gear out of park. need help. I have 150k mls. Thanks
98 ls400 blk w/nav
Old 07-20-09, 11:38 PM
skperformance
skperformance's Avatar
fuse ,did you check them ?
Old 08-20-09, 11:15 AM
concept98
concept98's Avatar
When checking fuses, I found a cartridge type fuse that looks bad. The copper band connection at the top you look at is still together but you can tell it over heated because I see burn marks at the bottom of fuse. It is a 120A fuse. When I tried to pull the fuse only the outer casing came out and I can see where the fuse is melted a little bit ant the bottom. Is it a tool that you r suppose to use to pull these types of fuses? Thanks
jazzzman
NX - 1st Gen (2015-2021)
05-01-23 10:01 AM
MikeGX740
GX - 1st Gen (2003-2009)
07-31-18 08:03 AM
Vitalxs
01-04-17 08:56 PM
Owaissidd
01-24-14 01:01 AM
Quick Reply: 98 ls400 w/NAV electronics dead
