Lexus struts or sears??
Old 04-03-02, 10:31 PM
Pfunk
Pfunk's Avatar
Default Lexus struts or sears??
I'm trying to find out if there’s anything special about Lexus struts. Any info??? The dealer wants $58 each for the front and $65 for the back.
Old 04-04-02, 01:11 AM
Manaray
Manaray's Avatar
Is that expensive or something?
I don't think there's anything "special" about the LS's suspension unless you have air suspension...I'm sure there are other brands of replacement Struts...but those prices don't sound too bad!
Old 04-04-02, 09:29 AM
hyperopt
hyperopt's Avatar
How much are the Sears' struts compared to Lexus' struts?
Old 04-04-02, 06:51 PM
Pfunk
Pfunk's Avatar
They cost about the same just sears has lifetime warranty and Lexus is 1 year. The Dealer charge $316 for parts and installation. I’m going to give it a try myself. I’ve installed 4 struts on a Honda in the past and hope it doesn’t require any major tools other than a spring compressor. Has anyone done it before? Anyone have a copy of the strut assembly from the service manual?
94 LS400
Old 04-04-02, 08:09 PM
retrodrive
Search Function Inc.
retrodrive's Avatar
Its real easy...do a search, there was a post about this earlier.
Old 04-05-02, 04:31 PM
ncdogdoc
ncdogdoc's Avatar
Default The right tools!
You will probably not have any problem, but definately have a ball joint puller (or any kind of puller for that matter) to disconnect the steering knuckle from the upper A-arm. You can get the strut out without one, but will never get it back. Ask me how I know
It is also easier if both front wheels are off the ground, gives you a little more leverage room. Here are the torque figures:
Steering knuckle ball joint - 46ft/lbs
center nut on shock - 26ft/lbs
three nuts on strut tower - 20ft/lbs
lower shock bolt to suspension - 106ft/lbs, recheck after settling or driving car
This is from memory - did it two days ago. I may have the 20 and 26 reversed.
The rear is another ball of wax, removal of rear seat, trim and shelf, along with disconnecting half shaft. Good luck. Front should not take you longer than 1-1 1/2 hours per side. I have not attempted the rear yet.
Old 04-06-02, 10:42 AM
Pfunk
Pfunk's Avatar
Yo guys have given me some really good information.
THANK YOU!
Old 04-06-02, 10:53 AM
Pfunk
Pfunk's Avatar
Does anyone know how long coil springs suppose to last?? Just wondering if I should replace them also.
Old 04-28-02, 07:11 AM
flexlex
flexlex's Avatar
Default Re: The right tools!
Man you got that right...I watched the guys at the shop do my rear shock and spring replacement yesterday and it was not a walk in the park. They did everything you mentioned regarding the rear seat... whew!!! I got tired just watching....
Old 04-28-02, 07:13 AM
flexlex
flexlex's Avatar
My original springs that were replaced yesterday were still in good condition (just a little rusty looking). For 176K, I'd say that they were in excellent shape. The guys at the shop said they were still good ....
hippchip
06-26-19 11:00 AM
pgpanos
Hybrid Technology
03-20-07 11:43 AM
radhead25
RX - 1st Gen (1999-2003)
12-28-05 03:28 PM
tantheman
11-26-03 11:16 AM
Quick Reply: Lexus struts or sears??
