1999 LS400 dies at stoplight
Old 06-30-09, 11:19 PM
valex
valex's Avatar
Default 1999 LS400 dies at stoplight
Hello, guys
Here`s the deal -first problem with my 1999 LS400 - 105K miles.After driving on highway I come to a traffic light and the car dies. VSC and CHECK Engine lights come on. Starts right up after that and the lights go off. Then a few days later same thing - first navigation screens starts flickering, AC makes funny sound, stereo pauses and then starts palying again and when I depress the breaks the car dies. VSC, Headlight leveling and VSC and CHECK Engine lightslights came on. I restarted the car, all lights went off except the CHECK Engine, it went off later that day.
Alternator problem?
Where would you start looking first?
Pure, I hope you will reply.
Thanks in advance.
Old 07-01-09, 12:09 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
get battery tested, then get alternator tested, sounds like one if not both are going out. most likely an alternator issue.
Old 07-01-09, 09:06 AM
valex
valex's Avatar
Default 1999 Lexus LS400 dies at stoplight
thanks, much respect
Old 07-01-09, 08:24 PM
trukn1
NELOC Mod
trukn1's Avatar
Def sounds like the signs of a dying alternator. Have the charging system checked at Autozone, or your local parts store. Most of those places don't charge anything to do the system check. Not to mention, your car is OBDII, just takes a code scanner to plug in to see what is going on.
Old 08-06-09, 11:13 PM
valex
valex's Avatar
Default 1999 alternator
I had the alternator checked,turned out it just started getting bad - 13 volts, supposed to be 14 or a little over. So, I ordered one from Carson, installed it today. The old one gave me problem just 2 or 3 times, but I decided not to wait and changed it.
Is the old one of any value? Can it be returned for core?
Old 08-06-09, 11:25 PM
avalon42
avalon42's Avatar
Depends entirely upon your parts supplier. Usually the core charge is around $30-50. If you rebuild it, you are looking at about that much to pay for the parts, assuming you did the labor to change the contacts, plunger and brushes yourself. Then you'd have to assume that the other parts are not going **** up later.
Old 08-07-09, 10:35 AM
atoyot
atoyot's Avatar
some alternators can be refurbished with just contacts and brushes. I know on my toyota land cruiser i did that for like $10. Not sure if the lexus alternator can be rebuilt the same?
badelbow
02-10-24 06:32 PM
aymaddemir
10-22-18 11:44 PM
fatcat2
07-17-18 04:08 PM
billycool
06-26-17 08:10 AM
99LS400BLK
04-26-07 07:40 AM
Quick Reply: 1999 LS400 dies at stoplight
