LS40 1st gen headlight questions
Old 07-04-09, 03:55 AM
  #61
JimsGX
JimsGX's Avatar
I tried grounding the passenger side 9004 ground pinout but that didn't fix the problems.
I'm thinking now that the relay that comes with the kit isn't drawing enough amp's from the OEM harness, so the car doesn't think the headlights are on. This would explain why the fogs won't come on and why the high beam indicator on the instrument panel won't illuminate when the high beams are on. I think I'm going to try and find a relay that will draw more amps off the OEM harness to simulate the draw of the 9004 halogen bulbs. Otherwise I'll be returning the kit and finding a different manufacturer.
Jim
Old 07-06-09, 12:07 AM
  #62
jcrome04
jcrome04's Avatar
I'm glad I waited for you to order...
Do you think it would make a difference if you ordered a 55W kit?? But even if the Headlights really were both burnt out the fogs should still come on... if everything is turned on..
Would it be best to make sure there is a relay for EACH side?
I still want an HID kit.. just not this particular one anymore...
Are there any vendors here on CL that deal with HIDs??
Old 07-06-09, 12:24 AM
  #63
jcrome04
jcrome04's Avatar
Ok so here's what I'm looking at now...
The XenonDepot H4 / 9003 5000k Bi-Xenon Xtreme HID Conversion Kit. 35W
Regularly $499.99 on sale for $219.99..
Comes with:
2 x 5000k Laser Calibrated HID/Xenon Bulbs
2 x Xtreme HID Digital Ballasts
2 x Complete Wiring Harnesses – 1 per side
Mounting Hardware
Complete Instruction manual
1 year ful replacement warranty
Separate fuses and relays for each side.. Sounds like a very nice kit. I've heard very good things about Xenon Depot too.
http://www.kbcarstuff.com/Xtreme_HID..._2001_s/21.htm
($25 discount code for CL members too)
Old 07-06-09, 06:21 AM
  #64
JimsGX
JimsGX's Avatar
Comes with:
Mounting Hardware
I think that kit would be a good way to go. I have a kit from them in my GX and I'm very happy with it. I'm planning on getting this same kit if my current problems can't be worked out. I like having two separate relays which my GX kit has but the LS kit doesn't. Let me know if you buy it and how it works out.
Thanks
Old 07-06-09, 06:32 AM
  #65
JimsGX
JimsGX's Avatar
Jcrome04,
Can you post a link to that specific Xenon Depot HID kit please.
Thanks
Old 07-06-09, 09:13 AM
  #66
jcrome04
jcrome04's Avatar
Here ya go Sir
http://www.kbcarstuff.com/Xtreme_Dig...ts_p/xt-5k.htm
Discount codes are in the Vendor Marketplace here.
https://www.clublexus.com/forums/clu...unt-codes.html
Old 07-06-09, 01:39 PM
  #67
L_Sport
L_Sport's Avatar
in addition to the HID's (I installed mine, SICK) is anyone running the EBAY headlight units? Clear glass, think it might work well with HID's...
ALIAS
Old 07-06-09, 02:16 PM
  #68
PureDrifter
BahHumBug
PureDrifter's Avatar
Python's running them, and they are plastic, not glass.
Old 07-07-09, 05:15 AM
  #69
JimsGX
JimsGX's Avatar
Originally Posted by [url
http://www.kbcarstuff.com/Xtreme_Digital_HID_5000k_Xenon_HID_Kits_p/xt-5k.htm[/url]
Unfortunately I have a 91 first gen so this kit won't fit since its made for 9003/H4 bulbs. Xenon Depot sells a 9004 bi-xenon set but the manufacturer is VOLT instead of Extreme HID and the kit only uses a single relay.
Are you going to go for it?
Jim
Old 07-07-09, 05:21 AM
  #70
JimsGX
JimsGX's Avatar
LSport,
WHich HID kit are you running? Are they bi-xenon? Everything else works okay afterwards? Fog's/Dash Highbeam light?
Old 07-07-09, 07:12 AM
  #71
python
python's Avatar
when i had hids in mine(fluted glass stock lens) i had a problem with one of the lights not comming on(and one time it would be the drivers side and then the passenger side), i had to turn the lights off and back on,this didnt happen all of the time
Old 07-07-09, 11:09 AM
  #72
jcrome04
jcrome04's Avatar
Yeah that kit is only a Bi-Xenon for H4.
Old 07-31-09, 06:17 PM
  #73
JimsGX
JimsGX's Avatar
Is the shield on the attached pic of a 6000k bi-xenon HID bulb off by 180 degrees? The arrow is the top of the headlight. Goes in facing straight up and turns to the right about 30 degrees or so. When installed, it puts the shield at the bottom of the bulb, towards the ground. Both of the bulbs I just received in a HID kit from XenonDepot for the first gen / 9004 bulb.
Old 11-18-09, 09:43 AM
  #74
Twix
Twix's Avatar
Originally Posted by JimsGX
2.) When you put the high beams on, the high beam indicator doesn't light up on the instrument cluster anymore.
Sorry to bring this thread up after quite some time, but have you managed to sort this problem out as I'm expiriencing exactly the same (1993 LS)...
Now at least I know why is it not working (high beam indication inside cluster), after 4 hours of messing around the cluster and bulbs inside it
Old 11-18-09, 12:23 PM
  #75
JimsGX
JimsGX's Avatar
No, never got it to work... I tried putting the standard 9004 halogen bulb back into the unused passenger side socket while still having the HID's fully wired, but that didn't allow the high beam light or the fog lights to come on either. The 9004 bulb wouldn't light up either.
I think the problem (at least partially) is that when the HID harness is plugged into the OEM headlight harness on the drivers side, it doesn't draw its power from it. It gets its power from the fused battery connection on the new harness so the high beam indicator and fog lights aren't working because there's no power draw to trigger the OEM relays. Just a theory.
I ended up putting Eagle Eye headlights in recently and I'm running the HID's with those. I was blinding oncoming cars with the stock headlight assembly's. Since I switched to the Eagle Eyes, the HID light output is better and oncoming cars aren't flashing their lights at me anymore. The beam pattern isn't too bad. Nothing compared to having a distinct cutoff line with projectors fitted, but very acceptable to me.
I'm going to wire in the fog's so they're used as DRL's. I bought a couple of H3 LED bulbs to be used for this purpose.
Jim
Quick Reply: LS40 1st gen headlight questions
