Check engine light and traction control light are on at the same time
Old 06-22-09, 07:23 AM
wqqclhtt
wqqclhtt's Avatar
Default Check engine light and traction control light are on at the same time
Hi every one, yestoday morning when I started My 96 LS400, the engine stalled but everything is Ok when the engine warm up. but today morning the engine still stall when it is cool and while I driving the check engine light and traction control light come on at the same time. I feel the drivebility remain the same.any one can help me with this problem? by the way, the car has only 88,000 mile on it.
Old 06-22-09, 07:31 AM
trukn1
NELOC Mod
trukn1's Avatar
IIRC, your car is OBDII, check with a local Autozone store, or someplace that has a scanner to pul the code from the car's computer. This will help in narrowing down some possible causes.
Old 06-23-09, 11:48 PM
doyo
doyo's Avatar
In my '92, whenever the CEL turns on, the Trac Off light turns on as well. The traction control was made to turn off if there's a CEL, so I think there's no problem with your TCS. Unless they changed it for the 2nd gen, you most likely only have a code(s?) for the engine.
You've got OBDII, so as stated, you'll need to get it scanned.
Old 07-01-09, 12:42 PM
wqqclhtt
wqqclhtt's Avatar
Thank you guys. I have my car scanned at Autozone, the clerk said it is the spark plugs.
I check the air filter and found it was really dirty. I thank the engine light was caused by the dirty filter and humidity. I replaced it and disconeted the battery and reconeted it. The lights went off and never come on in a couple days. But I thank it is time to replace spark plugs and wire set. I have got them and do it this saturday.
Old 07-01-09, 12:44 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
what code did he pull?
i'm always suspicious when a clerk working at a PARTS store tells me my car needs some new PARTS instead of telling me the code he pulled and rationale behind the recco..
Old 07-01-09, 07:43 PM
sha4000
sha4000's Avatar
Since when does the computer throw a code for spark plugs.
TroyzLegit
08-18-18 03:07 PM
greg0723
03-10-18 05:54 AM
dangt84
02-18-12 10:15 AM
chriswins
08-20-09 05:27 PM
BULL3T
01-18-03 02:54 PM
Quick Reply: Check engine light and traction control light are on at the same time
