horse power potentials?
Old 06-16-09, 06:33 PM
fastlex99
fastlex99's Avatar
Lightbulb horse power potentials?
i got a 99 LS 400. it's got the standard 290 horses and 300lbs of torque. it i was to add some performance up-grades to it whats the max amount of horse power that can be added to the car with out haveing to change out the internals of the car?
Old 06-16-09, 08:09 PM
gmacrae
gmacrae's Avatar
I'd imagine the rods in your engine will **** themselves around 500hp. You could get there with nitrous but it might be tricky with boost as your engine is quite high compression.
Old 06-16-09, 09:30 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
it's hard to say power wise, but the vvt-i rods have been seen to fail on roughly anything over 8ish psi.
please search, this has been asked before many times.
Old 06-17-09, 06:14 PM
fastlex99
fastlex99's Avatar
why woul the ros fail aroun 8 psi? it's a strong engine. 8 psi souns a little weak. i was thinking aroun 20psi since it is a V8
Old 06-17-09, 07:01 PM
PureDrifter
BahHumBug
because 95+ 1UZ (LS400) and 96+ 1UZ (SC400) have skinnier rods than the early model engines and have been seen to fail around that mark.....
whether something is a v8 or whatever has absolutely nothing to do with how many pounds of boost it can take.
Old 06-21-09, 02:03 PM
fastlex99
fastlex99's Avatar
is it possible to swap a LS400 engine for a LS430 engine? or are there differences in the engines other than the sizes?
Old 06-21-09, 04:43 PM
PureDrifter
BahHumBug
just go search buddy.
Old 06-21-09, 04:51 PM
dfkd
dfkd's Avatar
I swear I read somewhere that someone twin turbo'd one and mounted it in a boat doing about 800hp.
Old 06-22-09, 09:55 AM
3UZFTE
3UZFTE's Avatar
As PD said, search.... More than likely if he is running a TT setup in a boat, he has gone with forged rods & pistons. No one is saying it not a strong engine, all he is saying is search......... CL, Lextreme, V-eight, Google... As the saying goes, if you have to ask, it's probably not for you..
gsean400
Performance
23
07-08-15 01:00 PM
JesLet
Maintenance
11-13-13 07:02 AM
morbid
SC- 1st Gen (1992-2000)
13
10-24-09 12:40 PM
curtains
Performance & Maintenance
24
05-27-09 09:25 AM
Quick Reply: horse power potentials?
