Rear Brake Sliders
Old 06-09-09, 09:51 AM
JimsGX
JimsGX's Avatar
Default Rear Brake Sliders
Hi,
The rear brake sliders on my 91LS only have the fluted rubber bushings on the bottom sliders. The top sliders on both sides don't have the smooth bushings. Is this normal, or should the top sliders have the smooth bushings, just like the fronts? Picture of sliders attached (courtesy of Lexls.com).
Thanks
Old 06-09-09, 10:03 AM
3UZFTE
3UZFTE's Avatar
It is normal, mine has the same thing, bushing on the top and not on the bottom.
Old 06-09-09, 10:11 AM
JimsGX
JimsGX's Avatar
My rears have the fluted bushing on the bottom's and just the sliders without bushings on the rear tops. Are you saying yours are the same?
Thanks
Old 06-09-09, 11:42 AM
JimsGX
JimsGX's Avatar
Maybe I can rephrase this... Does anyone know what the OEM brake slider/bushing configuration is for all four wheels on a 91LS...?
Thanks!
Old 06-10-09, 09:04 AM
3UZFTE
3UZFTE's Avatar
Thanks!
I am just telling you my setup, I purchased my car from a guy who didn't maintain the car well. So maybe he flipped them backwards, or maybe he didn't. I am not sure of the all 4 wheels, but I know most Toyotas come with one solid slider, and one with a rubber bushing, and I've never questioned it as I was doing the brake job, so I'm not really sure.
Old 06-10-09, 05:21 PM
JimsGX
JimsGX's Avatar
Thanks 3UZFTE,
I got an exploded view of the brake components for the 90~94 LS from my local dealer. For the front, it shows a rubber bushing part number for the upper sliders which are smooth bushings, a part number for the lower sliders, which is a fluted bushing, In the rear, it shows a part number for the lower slider bushing, which is fluted and just a slider for the top without a bushing on it. I'm assuming this is the correct configuration.
Can anyone confirm this?
BTW - You can order just the bushings. You don't need to order the whole slider which retails for around $17 each (x8).
Thanks...
Bankswood
Suspension and Brakes
09-02-14 06:49 PM
StevieA
12-05-12 04:46 PM
lextechGS
11-11-09 07:06 PM
python
09-09-08 06:16 AM
Quick Reply: Rear Brake Sliders
