Heated seats not working
Old 12-02-12, 11:34 PM
  #31
PureDrifter
BahHumBug
PureDrifter's Avatar
97 chassis and engine stuff will be the same, but wiring will be a little different.
look for a '95/96.
Old 03-05-14, 12:19 PM
  #32
Sewpra
Sewpra's Avatar
Originally Posted by eles400
my 92 ls400 the drivers seat heater works only a little bit, the passenger seat works perfect, what can be done?
Originally Posted by mkaye
there are 2 elements in each heater wired in series with the other heater
so basically 2 heaters in parallel
if 1 breaks, then you get 1/2 heat in that seat
it's not rocket science, but time consuming to pull the seat and peel the leather back enough to remove & fix the heater
my mechanic gave me a tool & hog ties (the clips that hold the leather), but i found i could open the existing ones & reuse, but tie-raps would have worked too
there are 2 3-pin connectors in the back of the seat, with an ohm meter you can determine which heater element is open
mark
Isn't this incorrect? I read on a different thread if one goes out it takes the other with it.
I'm having the same problem as eles with my drivers seat, takes very long to heat up and when it does, I'm sure it's not reaching optimum heat. I searched and couldn't find anything about taking long to heat up and low temp, I only found explanations of the back cushion and bottom cushion being wired together resulting in one dead element taking out the other.
lexusls95
11-23-10 03:52 PM
thedivisio
07-10-07 09:56 AM
inkwell500
Maintenance
01-27-06 12:00 AM
SoarerNY
SC- 1st Gen (1992-2000)
12-27-05 04:42 PM
Plum
03-18-03 08:23 PM
Quick Reply: Heated seats not working
