Does Minor Leak in Steering Rack and Pinion Matter
Old 05-10-09, 07:56 PM
hookem59
hookem59's Avatar
Default Does Minor Leak in Steering Rack and Pinion Matter
I have a very minor leak in my 1996 LS400's (w/ 151k miles) rack and pinion assembly. When I say minor, I mean I have to replace (literally) a couple of ounces of steering fluid every three or four weeks. Otherwise, I do not experience any mechanical problems with the steering whatsoever. Of course the Toyota dealer says I need to replace the steering assembly. My question is: does this steering fluid leak even matter? Can I just top off my steering fluid every few weeks, or am I inviting a serious problem in the future? Also, is replacing the entire steering rack and pinion assembly a DIY? For reference, I was able to replace the ball joints and strut rods myself. Thanks in advance for any opinions!
Old 05-10-09, 10:28 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
leave it, you'll be alright up until the leak gets worse.
Old 05-10-09, 10:33 PM
Bali26
Bali26's Avatar
As long the leak is not at pump, no problem. I have the same kind of leak from my PS rack, so i add couple of ounces every month. You could replace the rack and tie rods too, its not too hard, might need an alignment later.
D3AN
Suspension and Brakes
62
01-12-18 05:00 AM
Dallasguy1
GX - 1st Gen (2004-2009)
20
06-29-16 07:23 PM
Sactolex
Performance & Maintenance
22
03-07-16 03:47 AM
Farino81
06-08-09 11:14 AM
Luxor
Maintenance
01-21-07 10:36 AM
Quick Reply: Does Minor Leak in Steering Rack and Pinion Matter
