Wont Start... =[
Old 04-27-09, 06:02 PM
whodablarg
whodablarg's Avatar
Exclamation Wont Start... =[
Well i finaly had the chance to change my motor mounts, took me 3 days but i got it, after i drop the car and decide to start it, it decides it would rather not start. I dont even get a crank, if anyone could tell me whats wrong or what i could have accidently dissconnected i would greatly appreciate =]
Old 04-27-09, 09:36 PM
skperformance
skperformance's Avatar
Ground to the engine could have broken when lifting it up.
Also i guess you checked the fuses ?
Do you hear the starter solenoid click when turning the key?
Old 04-28-09, 05:57 AM
whodablarg
whodablarg's Avatar
i get ground all over the car im ganna check if i get ground on the engine but im pretty sure i do. i get no sound from the starter which tells me that the starter isnt getting power, i did check all the fuses and they are all good.
Old 04-28-09, 10:56 AM
Bali26
Bali26's Avatar
Do the lights turn on? Is the batt dead? Batt connectors ok? Did you forget to reconnect something? Should be 12V from batt +ve terminal to engine block. Or you could use a bulb and see if it light up.
Old 04-28-09, 02:32 PM
glenmore
glenmore's Avatar
When I changed the mounts on my 1990, I encountered two grounds:
1) Ground to the block on the right hand side mount and submount.
2) From my writeup: Release loom along the cross member. Release PS line along the oil pan. Remove oil filter. Release plug on oil sensor. There is also a ground to the block and a loom holddown to the block here, 12mm.
glenmore
1990 LS400
1991 300CE
2000 C280
Old 04-28-09, 07:56 PM
whodablarg
whodablarg's Avatar
Resolved,
lol the issue was pretty simple and it took me a while to figure it out, when i first got in the car to turn it on the window was open and i tried to start it without unlocking the door so the alarm was set i guess and because of that i wouldnt start, i had to lock up the car and unlock it from the outside then i got it going.
but one more question about the mounts, i dont think i have them as tight as the should be since i couldnt get a gun up there, its giving me a slight vibration in the car, is there a simple way to get to the mounts and tighten them =P
DertyDOH
23
10-20-17 09:51 AM
mick_foley
06-06-08 06:27 AM
Grd4Spd
16
11-05-04 09:03 AM
GReenGS400
10-21-04 04:26 PM
Taka
SC- 1st Gen (1992-2000)
10-10-02 02:34 PM
Quick Reply: Wont Start... =[
