This Forum is Sponsored By:
Go Back   Club Lexus Forums > Lexus Model Forums > LS Models > LS400
Thread Tools Display Modes
Old 04-15-09, 07:55 PM   #1
98LS
Trader Score: (0)
Default Tail Lamp Failure
I keep getting a tail lamp failure warning. The passenger side brake light on the trunk side is out. I changed the bulb and the fuse but the light is still out.
Any ideas as to what may be causing this?
98LS is offline   Reply With Quote
Old 04-15-09, 08:24 PM   #2
trukn1
NELOC Mod
Trader Score: (0)
trukn1's Avatar
Send a message via AIM to trukn1 Send a message via Yahoo to trukn1
Check the wiring harness on the left trunk hinge under the cover. Possible that one of the lines may have gotten pinched or burned out. If so, cut out burned area, replace with new wire. Trunk wire harness is pretty common problem.
__________________
[i]http://www.clublexus.com/gallery/data//500/trukn1sig.jpg[/img]
"Futility can only be prosperous when you maintain the integrity of imagination!!" --Trukn1
trukn1 is offline   Reply With Quote
Old 04-15-09, 08:49 PM   #3
hobojoe
1991 Lexus LS
Trader Score: (0)
hobojoe's Avatar
Send a message via AIM to hobojoe Send a message via Yahoo to hobojoe
http://www.lexls.com/tutorials/lighting/bulbout.html there ya are :]
__________________
Mike. 91_LS400~EclipseNav~Focals~15%~Clear Turns~Custom Injen Intake~D/S Rotors~SS Lines~Rays GT-7~ Dual 2.25 catback W/Xpipe~Megans~RCR Tails~
hobojoe is offline   Reply With Quote
Old 04-15-09, 08:55 PM   #4
LiCelsior
1993 Lexus LS
Trader Score: (15)
LiCelsior's Avatar
think this applies to his 98 though? i know this was common with the 1gen but not the 2gen.
__________________
RIP Liz 7/18/09
TLN 5.0 up and running!! #93
My Previous 93 セルシオ, http://www.rimtuck.com/setup.php?id=766
LiCelsior is offline   Reply With Quote
Old 04-15-09, 09:14 PM   #5
hobojoe
1991 Lexus LS
Trader Score: (0)
hobojoe's Avatar
ooooo didnt notice the 98 umm if its still run in the same place i would guess so....
__________________
Old 04-16-09, 09:35 AM   #6
98LS
Trader Score: (0)
Thanks everyone, I'll check the wiring harness.
Old 04-17-09, 10:27 AM   #7
19psi
1998 Lexus LS
My Garage
Trader Score: (0)
19psi's Avatar
did you get exactly the same bulb that came out when you replaced it? some bulbs work but they're sligtly different in wattage which will still cuase the failure light to activate.
__________________
Dodge Ram cummins turbo diesel, 5 speed, 344 HP, 788lb.ft. 18/21mpg, shooting for 1000 lb. ft. on stock turbo.
Kawasaki Ninja ZX-12R 1200cc's, 190 hp of pure evil on 2 wheels.
95 Jeep Cherokee BDS/hybrid 5" lift, 32x11.5 BFG mt's, welded rear diff, long arms, etc. trail beater.
19psi is offline   Reply With Quote
Old 04-17-09, 11:15 AM   #8
PureDrifter
1999 Lexus LS
Trader Score: (8)
PureDrifter's Avatar
Send a message via AIM to PureDrifter
Quote:
normally this is a problem with LED bulbs due to the lower resistance and power draw.
__________________
1.Black on Black 1999 LS400 PM-spec
-Maya-Megan-Magnaflow-Aerotect-Xenondepot-CarsonTuned-Hardwired Ipod -
2. Black on Black 2000 LS400 Platinum Series SE-spec
3. Ebony Teal 1995 LS400 11-8-06
PureDrifter is online now   Reply With Quote
Old 04-24-09, 07:06 AM   #9
smokincigs
Trader Score: (0)
Did you get this problem fixed?
smokincigs is offline   Reply With Quote
Old 04-24-09, 03:35 PM   #10
qewani1
Trader Score: (0)
qewani1's Avatar
Taillight does not come on.
(Headlight is normal) , start inspecting the following :-
1. TAIL Fuse (Instrument Panel J/B) located in driver side.
2. GAUGE Fuse (Instrument Panel J/B) located in driver side.
3. Taillight Control Relay (Instrument Panel J/B) located in driver side.
4. Light Failure Sensor
5. Light Control Switch
6. Body ECU
7. Wire Harness
__________________
2000 LS400
"Anyone who has never made a mistake has never tried anything new." - Albert Einstein
DIY for all LS400 Models.
http://celsiorup.com/
qewani1 is offline   Reply With Quote
Old 04-24-09, 04:09 PM   #11
Big Steve
Trader Score: (1)
Big Steve's Avatar
Send a message via AIM to Big Steve
check the 3rd brake light? i had my 3rd brake light go out and i didnt realize that there were 2 bulbs in there..
Big Steve is offline   Reply With Quote
Tags
400, code, failure, forums, hinge, lamp, lexus, lexustail, ls, ls400, replace, sensor, tail, taillamp, trunk, wire
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
