high beam/fog switch mix up
Old 04-08-09, 08:38 PM
93LSexy
93LSexy's Avatar
Exclamation high beam/fog switch mix up
Hey guys,
Got a little bit of an issue with the fog light switch which I can't figure out for the life of me. The fog light is no longer working, checked the fuse, it was fine, for the heck of it, I even changed to a new 15A fuse...nothing. Then I realized, the damn fog light switch is now controlling the high beam!!! When I turn the fog light switch to on, it turns the headlights to high beam!!! what the??? the blue light in the dash that indicates the high beam on is no longer working whether the high beam is activated through the normal way or the new fog light switch way.
So please...could someone help? I don't even know where to start and have no idea what caused this.
thanks alot.
Old 04-09-09, 10:35 AM
MEANDAFAKA
MEANDAFAKA's Avatar
idk man, i guess check the wiring???
Old 04-09-09, 11:52 AM
jcrome04
jcrome04's Avatar
Maybe give this a shot??
http://www.lexls.com/tutorials/lighting/bulbout.html
If not that maybe you need a new stalk.
Old 04-09-09, 09:16 PM
skperformance
skperformance's Avatar
The stalk is broken somehow.
Old 04-10-09, 03:31 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
find a local wrecker and swap out the stalk, it's easy and should be a cheap part.
GAISF
IS F (2008-2014)
10-27-16 11:22 PM
LudeNsoL
05-23-12 10:10 AM
antmck33
04-30-12 07:45 AM
slk_dds
05-11-07 11:59 PM
RefinedGS
11-07-04 11:44 AM
Quick Reply: high beam/fog switch mix up
