Gas gauge not working, "E" light always on, help.
Old 04-04-09, 06:33 PM
Kruso
Kruso's Avatar
Default Gas gauge not working, "E" light always on, help.
Hi guys, recently picked up a 93 LS400 and the gas gauge always shows empty. Car also had a problem with the interior cluster and climate control unit not lighting up/ flickering.
I HAVE gone ahead and replaced the three recommended capacitors listed below:
C142[big board]4.7uf,25 volt
C147[big board]10uf ,50 volt
C212[small board]10uf,16 volt
And that fixed all the lighting issues (thanks to CL!) but the gas gauge is still sitting on empty. Now I'm wondering if there's another capacitor that needs to be replaced for this exact problem or the level sender unit inside the trunk is defective.
I did read on another post (https://www.clublexus.com/forums/ls4...lems-help.html) where Ron1973 replaced capacitor C214 aswell but I see that mentioned nowhere else. Any help appreciated.
Kruso
Old 04-04-09, 08:56 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
check the trunk hinge wiring harness for the interior problems before all else.
Old 04-05-09, 08:09 AM
MEANDAFAKA
MEANDAFAKA's Avatar
^2nd that, check the wiring on the trunk.
Old 04-06-09, 12:51 PM
Kruso
Kruso's Avatar
On it! will post back in a few hrs.
Old 04-06-09, 05:40 PM
Kruso
Kruso's Avatar
No dice... tore the tape through most of the wire and all seems fresh, nothing broken. Maybe someone can point me in the right direction as far as where exactly the wire breaks from.
Old 04-07-09, 12:34 AM
AzHotLS
AzHotLS's Avatar
Since you already replaced the caps, you saw this then, right?
http://us.lexusownersclub.com/forums...showtopic=5822
Could be the sending unit then.
Old 04-07-09, 10:22 PM
Kruso
Kruso's Avatar
Yes I replaced the cap and that post contains the same picture that is floating around all over the web and multiple threads here on CL. Its not the sending unit, I've taken it apart and verified functionality by bypassing it altogether.
I dont think anyone else have ever had a problem where the gauge read empty with the orange warning light on.
Kruso
Old 04-08-09, 12:53 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Kruso
I have on my 98. replacement of the sending unit fixed the issue.
Old 02-09-10, 05:38 PM
teKcirc
teKcirc's Avatar
Default Have you got the solution?
I have the same problem with my LS400 94', just wonder if you have find the solution for this problem?
Thanks
Kruso
Old 02-12-10, 12:00 AM
teKcirc
teKcirc's Avatar
I do have exact problem like your and I just replace the C142 and it work great now.
If you have a yellow warning light on when the tank actual empty, that mean the float and sending unit is working.
Are you sure that you put the right cap for C142 and the right way
Kruso
JLFitment
GS - 1st Gen (1993-1997)
01-16-14 10:13 AM
DonCorleone
09-09-11 07:48 PM
boxcarfan
06-05-10 03:07 PM
suprandsc
Performance & Maintenance
01-22-08 05:56 PM
1sxyrxy
10-30-06 09:50 PM
Quick Reply: Gas gauge not working, "E" light always on, help.
