first Gen ls problems with ipod adapter. Help the n00b <----
Old 03-26-09, 11:13 PM
savala88
savala88's Avatar
Default first Gen ls problems with ipod adapter. Help the n00b <----
Needing some help I bought the monster icarplay cassette adapter for my 1990 LS400. Had high hopes I would be able to listen to my favorite music in my first Lexus but No. First off I can hear the music but its very very quiet and there is a hissing noise that is not usually there. then after about a minute the cassette is popped back out. Im assuming I dont know how to use the radio since I just barely got this car, are there any tricks I should know about that would help me fix the problem?
thanx in advance
Old 03-27-09, 12:09 AM
vietunit
vietunit's Avatar
Let me get this straight, you put in the cassette adapter and heard the music but it was very low with a hissing sound. Then the cassette adapter popped back out? Try putting it back in? Try switching from radio to tape, FM1/2 to tape?
Problem with my car is when its chilly or during the morning, the tape player fails. Sounds is low with a hissing noise even when volume is maxed in the car and the ipod. To relieve some of this, I usually have the radio on fairly loud when I'm warming up my car. (5-10mins give and take) By the time I am ready the go, the sound isn't as low and actually acceptable. Its fine after that for the rest of the day and gets better, don't know why. Its kind of like my car doesn't like being cold.
Don't know if any of this was useful to you but just sharing because I have a similar situation. For the cassette being popped back out, I'm not really sure, it may be your cassette player and it's time to buy a FM Transmitter.
Good Luck.
Old 03-27-09, 12:19 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
hardwired iPod FTW!
Old 03-27-09, 01:36 PM
genetic
genetic's Avatar
My tape pops back out when I do this also.
so I said forget it haha.
Old 03-27-09, 07:42 PM
JimsGX
JimsGX's Avatar
thanx in advance
Make sure Dolby Digital isn't turned on, it's turned on/off by pressing preset #6 when the cassette is loaded and playing. Bump up the volume directly on your ipod... Also, soak a Q-Tip in alcohol and hold it with a pair of needle nose pliers. Open up the tape door and clean off the tape head inside the tape player. You may need a flashlight to help you see the head inside.
Old 03-29-09, 12:49 AM
savala88
savala88's Avatar
hey guys so i figured it out by total accident! while messing with the stereo i accidently turned the stereo off while the tap was still in and when i turned it back on it started playing perfectly!
Old 03-29-09, 09:02 PM
qha_vn
qha_vn's Avatar
why dont you hardwire the HU so that ipod can connect via standard RCA inputs. I did it and result is great
Old 01-05-10, 10:35 AM
skinsfan68
skinsfan68's Avatar
how does the hardwire ipod work exactly?
Old 01-05-10, 10:41 AM
LiCelsior
Retired
LiCelsior's Avatar
Puredrifter has a extensive thread in the Audio section of this forum..go check it out.
647TTA
RC F (2015-present)
08-23-17 04:09 PM
Lextra
GS - 1st Gen (1993-1997)
03-17-11 01:54 PM
*Batman*
06-14-10 09:42 AM
bberisford
05-01-06 06:45 PM
Butter04
01-06-06 10:41 PM
Quick Reply: first Gen ls problems with ipod adapter. Help the n00b <----
