DIY // LS400 Headlight Restoration // Before & After
Old 03-23-09, 12:54 PM
qewani1
qewani1's Avatar
Default DIY // LS400 Headlight Restoration // Before & After
DISCLAIMER:
Use this guide at your own risk. I cannot guarantee that it will work for everyone. I cannot guarantee that everyone will be happy with the results. I do not recommend this unless if your headlights are really really bad as mine were. Furthermore, this guide is intended to assist those who planning to replace their foggy headlights & saving some cash by trying at least first to restore the existing headlights. You are responsible for your own actions.
After viewing this thread which shows the directions of the restoration
https://www.clublexus.com/forums/automotive-care-and-detailing/285498-headlight-restoration-with-1500-2000-plastx.html
http://www.meguiarsonline.com/forums/showthread.php?t=20994
Here we Go!
Product
Before
Old 03-23-09, 12:55 PM
qewani1
qewani1's Avatar
After
Ended.
Meguiars <3
PlastX <3
Old 03-23-09, 01:06 PM
acidfire52
acidfire52's Avatar
WOW. I need to get some of that.
Just follow the directions?
Old 03-23-09, 01:32 PM
LiCelsior
Retired
LiCelsior's Avatar
i hope u put a coat of wax over that...or ur gonna need to do it again in a month. all plastx does is remove the oxidizing UV blocker on the headlights. if u put a layer(s) of wax then it'll act as the uv blocker.
Old 03-23-09, 02:00 PM
avalon42
avalon42's Avatar
Instead of the coat of wax, I would use a spray-can clear coat. LiCelsior is correct, it will oxidize even faster without it.
Old 03-23-09, 07:40 PM
Kansas
Kansas's Avatar
Another method of restoring plastic headlight lenses is to refinish them with a Crystal View kit -- http://www.myheadlight.com/
Both Photoinc and I refinished our headlights with Crystal View -- he provided before and after photos: https://www.clublexus.com/forums/ls4...eadlights.html
The Crystal View kit includes a clear sealer that smells like lacquer. The sealer dries as hard as a rock and provents the lenses from fogging up again.
Old 03-24-09, 08:57 PM
91ls400own
91ls400own's Avatar
Sorry but did not see much difference!
Old 03-24-09, 08:58 PM
91ls400own
91ls400own's Avatar
oops now I see!!
Old 03-24-09, 09:45 PM
Do.Man
Do.Man's Avatar
nice...what a difference!
Old 03-25-09, 01:35 AM
skperformance
skperformance's Avatar
The layer of dirt is the uv coating that has deteriorated.
Better add something back soon or it will yellow and return ,
A sealer or clear bra works best.
Old 03-25-09, 09:10 AM
MEANDAFAKA
MEANDAFAKA's Avatar
but all this only applied to plastic housing, but for 1st gen JDM headlight glass housing, it does not apply to us 1st gen guy.
andy08isf
IS F (2008-2014)
14
08-20-20 07:33 PM
rgeyer
29
04-01-14 10:16 AM
lostgs400
CL of Southern California
12-17-07 08:08 PM
Aristo94
GS - 1st Gen (1993-1997)
06-24-07 02:04 AM
vinh
Lighting
11-05-04 07:04 PM
Quick Reply: DIY // LS400 Headlight Restoration // Before & After
