Electrical Problem!!!!!!!
Old 03-15-09, 06:48 PM
SPhoto
SPhoto's Avatar
Default Electrical Problem!!!!!!!
my radio, a/c, and cluster isn't working/lighting up!
all the other electrical works but those i listed...
could it be fuses? relays?
Old 03-15-09, 06:52 PM
LiCelsior
Retired
LiCelsior's Avatar
check your fuses...im gonna guess the DOME fuse under the steering wheel.
Old 03-16-09, 02:41 PM
SPhoto
SPhoto's Avatar
there's a fuse under the steering wheel?
or you talking about the fuse box under the kick panel?
Old 03-16-09, 06:05 PM
LiCelsior
Retired
LiCelsior's Avatar
yea kick panel...couldnt think of what it was.
Old 03-17-09, 02:19 AM
SPhoto
SPhoto's Avatar
oh i checked those fuses already
might be one of the relays or something
gonna get that checked out this wednesday
Old 03-17-09, 05:20 AM
cation
cation's Avatar
My 93 would do that intermittently before I took the cluster out and replaced the bad capacitors on the circuit boards. If all your fuses are good this is where I'd look next. Do a search on flickering cluster or flickering dash lights. You'll be able to identify what capacitors need replacing. If you have decent soldering skills this is a no brainer once you get the correct components. The hardest part of the whole operation is getting the wire harness detached from the cluster when you're trying to remove it from the car. Good luck.
Old 03-17-09, 06:27 AM
scott50
scott50's Avatar
It is possible that your reostat went out on you.
Old 03-17-09, 11:55 AM
SPhoto
SPhoto's Avatar
whats a reostat?
Old 03-17-09, 12:06 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
that little **** on the dash that controls the brightness.
Old 03-17-09, 01:14 PM
qewani1
qewani1's Avatar
its called
rheostat light control
Old 03-17-09, 08:20 PM
SPhoto
SPhoto's Avatar
oh no i meant the cluster doesn't light up and the needles dont work....
...plus i still need help on the radio and a/c
Old 03-20-09, 09:57 AM
avalon42
avalon42's Avatar
Get yourself something like this from Walmart $6.99.
http://cgi.ebay.ph/Auto-Tester-Heavy...ayphotohosting
Test ALL FUSES, car will be on in accessory mode, you ground the tester with the clamp and use the probe on either end of the exposed metal of the top of the fuse to test.
If not, try one of these specific auto fuse testors. http://images.orgill.com/200x200/3300316.jpg Usually comes in those packages.
Did these things just die suddenly or did you add/remove something electrical to your car recently?
Old 03-20-09, 10:38 AM
jeffls400
jeffls400's Avatar
I am willing to bet it is the 120A fusible link in the underhood fusebox. It is marked ALT on the schematic under the fuse box lid. Have you recently had a battery replaced, or has someone recently worked in the vicinity of the PS pump / alternator?
Old 03-30-09, 03:14 AM
SPhoto
SPhoto's Avatar
i was trying to rewire my foglights to the parking lights so it would stay on
then i shocked myself while the lights was on by touching the wires trying to connect everything good
then the ac, radio, cluster, and needles dont work
Old 03-30-09, 09:06 AM
jeffls400
jeffls400's Avatar
Hey naes, be careful! After that little piece of info, I am certain you have blown the 120A fusible link under the hood. If you remove the fuse box cover, the links will be on the left.
Jeff
Quick Reply: Electrical Problem!!!!!!!
