Help electrical problem!!!! '97
Old 03-12-09, 01:34 PM
skybluecrx
skybluecrx's Avatar
Unhappy Help electrical problem!!!! '97
I have a 97 Ls400 that has a recent issues. To get to the point.
-the side mirrors stop working
-the keyless entry stopped working
-the dome light stopped working when doors are opened, works as long as key is in ignition(door setting)
-doors lock/unlock only with key in ign
-trunk release only works with key in ign
All these functions stopped all at once and really want to get this fixed. All info to fix these issues will be appreciated....
Old 03-12-09, 02:12 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
1-search
2-check (actually TEST) all the fuses in the driver side fuse box under the dash by the parking brake release.
Old 03-12-09, 08:03 PM
skybluecrx
skybluecrx's Avatar
Default ?????
I checked the fuses and there good, Ive been searching havent found anything useful yet
Old 03-13-09, 08:26 PM
LEXTEK1
LEXTEK1's Avatar
Hello,
Check the 20a (Door) fuse and the 7.5a (Dome FR) fuse. They both are under the hood. This is a multiplex communication system and the body ECU controls all of the functions you mention. When the key is in the ignition, circuits are turned on that temporarily supply voltage to many systems in the Body ECU.
Good Luck!
Don
Lextek Automotive
Houston,Texas
Old 03-14-09, 12:11 PM
MEANDAFAKA
MEANDAFAKA's Avatar
anyone has pictures for the fuse box located under the dash? i can't find any pictures.
oh and in case you wonder why the hell i don't just look at my LS, the reason for this is due to i'm out of my state right now for my military assigment. thanks in advance.
Old 03-16-09, 01:05 PM
skybluecrx
skybluecrx's Avatar
thanks lextek more info is welcomed
Old 02-26-13, 08:10 AM
TaffyK20si
TaffyK20si's Avatar
skybluecrx, did you ever figure out what was causing this? I've had the same problem you described above on my 97 LS from quite some time. I feel like I've checked both fuses listed above. I'm thinking bad multiplex. Anyone else with this problem? Resolved?
Alexbenz
04-30-14 10:52 PM
hazepurple
07-14-11 08:05 AM
JAEBRODY
Maintenance
03-25-05 08:34 PM
Bj(CA)
05-06-04 06:07 PM
Quick Reply: Help electrical problem!!!! '97
