Transmission: Drain or Flush?
Old 03-27-09, 02:59 PM
  #31
Sens4Miles
Sens4Miles's Avatar
Just wanted to add my 2 cents to this thread. A few years ago, I had brought my LS400 in to have a tranny flush, thinking it would be a good idea to keep it clean and in good working order. Well, less than 2,000 miles after getting it flushed, the transmission failed and costs me almost $2,000 to get it rebuilt. Do yourself a favor and just do regular drain and fills. I will never ever do a flush on a car again after what I experienced.
Old 03-27-09, 11:17 PM
  #32
margarita
margarita's Avatar
Originally Posted by PureDrifter
trans and engine mounts.
Both transmission and engine mounts were fine.
Changing the transmission fluid seems to have improved shifting noticeably.
I've also changed what I do when I park it for the night (goes into neutral, set the emergency brake, let the emergency brake hold the tension, then it goes into park).
Big difference when shifting into gear the next morning.
Old 04-10-09, 07:06 AM
  #33
smokincigs
smokincigs's Avatar
I had mine flushed with the BG flush machine using the BG cleaner. I took 16 quarts of toyota t4 fluid and they put that back in it. I could tell a big difference in how it shifted. I can barely feel it shift now. It shifted very smooth before, but it made a big difference. The biggest noticeable difference is that the shift **** has absolutely no vibration in it anymore. I used to feel some vibration when driving down the road, but thehe vibration would stop if I put the car in neutral and coast. Now there is no vibration at all. Not sure why this is, but it is..
yackowski
GX - 1st Gen (2004-2009)
05-13-16 09:18 PM
Kalogerus
Performance & Maintenance
04-09-12 12:49 AM
en11871
27
03-17-08 09:56 PM
carguy07
RX - 1st Gen (1999-2003)
12
01-11-08 08:40 PM
cdvmagic
Maintenance
01-31-07 11:44 AM
Quick Reply: Transmission: Drain or Flush?
