TRAC light.
TRAC light.
i was driving the LS a bit today and noticed the TRAC light come on. didn't beat on the car or anything, just normal cruising. anyone know what causes this? the car is a '94.
Check the code first before you start spending $. The code or codes should be stored even the light is gone. I'm still fight my code 19. I'll be resetting the code again to see if that fix it. Just wanted to make sure. Then, I will be replacing the accumulator & pump.
mmartin888
Performance & Maintenance
06-08-14 08:11 PM
