Idler pulleys...bearings replaceable?
Old 01-19-09, 10:17 AM
yardbuzz
yardbuzz's Avatar
Default Idler pulleys...bearings replaceable?
I have heard that the bearings in the idler pulleys for the serpentine belt can be pressed out and replaced with locally available bearings in my 94 ls400. That would save a bunch of bucks.
Anyone know if this is the case?
thanks in advance.
Old 01-19-09, 12:13 PM
bicol-ini
bicol-ini's Avatar
yes it can be pressed out and in, in fact you can just place a socket of equal size or tad smaller and hammer it out,
heres for the tensioner pulley bearing # 6203 you got to get the sealed metal bearing code zz so its 6203zz about 6 bucks
for the idler pulley its # 6301zz for metal sealed bearing
theres also rubber sealed which is cheaper
Old 01-19-09, 02:33 PM
AZ Mike
AZ Mike's Avatar
FWIW, a serpentine tensioner pulley (Goodyear) is $21 at AutoZone. The Stealer quoted me $121.
Old 01-20-09, 05:30 PM
yardbuzz
yardbuzz's Avatar
thanks for the help.
andrewwake
02-26-21 05:46 AM
dashan
21
03-10-18 02:25 PM
mark98ls40
13
10-16-15 08:27 AM
deanbrown
10-25-08 06:06 PM
-J-P-L-
Performance & Maintenance
04-29-08 08:55 PM
Quick Reply: Idler pulleys...bearings replaceable?
