radio no sound
Old 01-01-09, 04:42 PM
RUDENESS
RUDENESS's Avatar
Default radio no sound
I have a 91 Ls 400 (212, 000 ) miles, my radio comes on but there is no sound, whats up with it?
Old 01-01-09, 05:18 PM
LiCelsior
Retired
LiCelsior's Avatar
check your fuses?
Old 01-01-09, 05:29 PM
RUDENESS
RUDENESS's Avatar
I thought that if it has a blown fuse that the radio wont have no power at all...
Old 01-01-09, 05:30 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
not necessarily, the illumination is controlled sepearately.
Old 01-01-09, 05:34 PM
LiCelsior
Retired
LiCelsior's Avatar
also, on the 1LS this was very common. if water got into the trunk, it'll hit the amp and it'll stop sound until it was dry. if u search, u'll see i also had this problem and EXEUCF10 helped me with this problem.
Old 01-01-09, 06:18 PM
RUDENESS
RUDENESS's Avatar
ok , I'll check the fuses in the morn. its brick outside right now...N.Y. is about 19 degrees right now...BRRRRRRRRRRRRRRRRRRRRRRRRRRRRR...
Old 02-21-09, 01:21 PM
RUDENESS
RUDENESS's Avatar
ok, I checked the radio fuse by the emerg. brake and the fuse is good, what do I do now?
Old 02-21-09, 03:34 PM
EUBT
EUBT's Avatar
Cool
Just noticed you've got 2 threads going on this. Try to keep it to one prob = one thread. Otherwise we can't follow what's been posted and it becomes a PIA to search for the continuity. So I'll repost in your other thread.
Old 02-26-09, 05:35 PM
RUDENESS
RUDENESS's Avatar
what other post are u talking about?
Old 03-02-09, 10:12 AM
JimsGX
JimsGX's Avatar
There's another fuse in the engine compartment that is for a factory installed cell phone. If that fuse blows, the radio will turn on but you won't get any sound. It's around the center of the fuse block, 15 amp I believe. Can't remember the location number but it will be in your owners manual.
Old 03-02-09, 02:46 PM
RUDENESS
RUDENESS's Avatar
I'll check that when the snow melts...thanks..
Old 03-02-09, 02:51 PM
LiCelsior
Retired
LiCelsior's Avatar
check the DOME fuse while ur at it. that may cause it.
Old 03-03-09, 10:11 AM
mista808
mista808's Avatar
Try keeping it on a low volume and see if u get some sound. When my battery died, I tried to start my car and nothing, my radio was on and I heard a pop.... thought nothing of it. Got a new battery in, and now my radio won't turn up past 1/4... any thing after that, the sound cuts out but the subwoofer still works....my system is a pioneer. Do you have pioneer or nakamichi? Pioneer systems, the mid/high speakers run directly off the head unit and the sub has an amp. The nakamichi system, all the speakers run through an amp first... possibly the amp may have taken a dump...
Diazg07
08-17-12 12:49 AM
justjosh
07-11-11 08:02 AM
justjosh
07-10-11 09:48 PM
lexus_sc40
07-12-09 10:19 PM
tytgs300
08-25-08 10:44 AM
Quick Reply: radio no sound
