1995 LS400 Hot Air
Old 12-21-08, 08:37 AM
techmech74
techmech74's Avatar
Default 1995 LS400 Hot Air
Car with 137K running great. Had the heater on and was taking a long winding
off ramp from the freeway and all of a sudden the AC button light comes on along with the AC. Since then the hot air comes on only for a few seconds (when requested) then goes cool, even with the temp setting to 85. Any ideas?
Thanks
Old 12-22-08, 01:18 PM
19psi
19psi's Avatar
check your heater valve up against the firewall. it may not be moving. there's an actuator under the dash connected by a cable to the valve. sometimes that actuator goes bad and leaves teh valve closed or partially open which results in not so hot air.
sam12345
10-14-13 04:54 PM
groverwood
Performance & Maintenance
07-08-13 06:21 AM
joevrat
12-01-06 12:03 PM
08046
Maintenance
11-23-04 08:49 AM
Quick Reply: 1995 LS400 Hot Air
