Six mpg, code 26, suggestions?
Old 12-07-08, 12:21 PM
Ls4hundred
Ls4hundred's Avatar
Default Six mpg, code 26, suggestions?
I have the leaking acv smoke, and an error code 26. Are these related and how can I get rid of the code 26?
Old 12-14-08, 01:38 PM
Ls4hundred
Ls4hundred's Avatar
This problem won't go away on it's own. I need some help guys.
Old 12-14-08, 02:00 PM
python
python's Avatar
1st gen LS? i think its the 02 sensor code isnt it?
Old 12-14-08, 02:08 PM
LiCelsior
Retired
LiCelsior's Avatar
yep, rich a/f malfunction...i got the opposite, lean a/f malf.
Old 12-14-08, 02:35 PM
python
python's Avatar
pre cat 02
Old 12-14-08, 06:01 PM
Ls4hundred
Ls4hundred's Avatar
Ok thanks guys. I can use a universal O2 sensor (read: cheaper) right? Also, do I just need one or do I need two?
Old 12-14-08, 06:19 PM
LiCelsior
Retired
LiCelsior's Avatar
if u changing one side its pointless cuz then it might be the other side...change both at once. also dont go like cheap cheap, use www.oxygensensors.com
Old 12-14-08, 06:46 PM
nthach
nthach's Avatar
The pre-cat O2s are heated 3 or 4 wire ones, the fronts are 2-wire non-heated ones. I've done mine a while back, but I used Walker brand sensors, the heated ones were Denso copies. If I was to do it again, I would use Denso, NTK(which is the OEM to Honda and Nissan, made by NGK) or Bosch.
If you don't want to deal with splicing in wires, RockAuto has decent pricing on the pre-terminated Denso sensors.
Old 12-14-08, 07:00 PM
Ls4hundred
Ls4hundred's Avatar
Ok so I need two 4-wire heated sensors? Why do you say you wouldn't use Walker again?
Old 12-14-08, 08:34 PM
nthach
nthach's Avatar
The Walkers are doing a fine job - after all the heated pre-cat sensors are Denso clones or made by Denso, but the 2-wire non-heated ones were of dubious quality.
Old 12-15-08, 07:28 AM
python
python's Avatar
i wouldnt use universal 02's either.....u start changing the length of the wires and u change resistance
Old 12-15-08, 11:55 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
true, but the change in impedence from the longer wire length (assuming you wouldn't just cut the excess off) would be so minute that the car would NOT misbehave.
aftermarket O2 sensors, installed properly, are perfectly fine.
Old 12-15-08, 01:51 PM
Ls4hundred
Ls4hundred's Avatar
Thanks a lot guys.
Old 08-10-09, 11:02 PM
damon
damon's Avatar
For those that like part #'s.
"Pre" front 02's
Toyota #89465-24050
NTK #24563
Denso 234-4211
Bosch # 13561
Airtex # 5S3561
Walker 250-24220
DeanWeen
GS - 1st Gen (1993-1997)
10-09-18 04:08 PM
RayN
RX - 1st Gen (1999-2003)
01-17-15 09:23 AM
Live4brew
17
10-23-12 12:24 AM
BostonSC4
SC- 1st Gen (1992-2000)
06-30-10 04:21 PM
squeekyM
09-26-06 07:36 AM
Quick Reply: Six mpg, code 26, suggestions?
