Need Help with 1uzfe Swap
Old 11-24-08, 09:39 AM
eyecon7
eyecon7's Avatar
Default Need Help with 1uzfe Swap
I have never done this.. but i need to swap a 1uzfe from my 90 LS to My 93 LS. I have read on lexls.com that the EGR and EVAP systems now controlled by the engine ECU and Fluid temperature sensor was added to the transmission on the 93.. is the a Write up on how to pull the motor...and how would i get around the EGR and Evap problem...
Old 11-25-08, 07:01 AM
eyecon7
eyecon7's Avatar
ttt..............
Old 11-25-08, 07:13 AM
Och
Och's Avatar
If you keep the old ecu, and old EGR/EVAP systems and just swap the engine, you'll be fine. If you want to install new system, you will need the new ECU as well.
Old 11-25-08, 11:56 AM
eyecon7
eyecon7's Avatar
cool thanks man... you think its possible to pull the transmission and engine out together with a cherry picker... I can't drop it... dont have a lift... and the 93 transmission is shot...
Old 11-25-08, 05:25 PM
Och
Och's Avatar
No clue man, theres a lot of things you can pull with a cherry picker
Putting in the new unit is a whole different story.
Richiephil
07-18-19 09:59 AM
Robnh
02-07-19 01:02 PM
Radmi
04-23-18 04:20 AM
Rblakely06
02-16-17 07:37 AM
ariasuriah
01-03-12 12:18 AM
Quick Reply: Need Help with 1uzfe Swap
