I am in need of some help!
Old 11-16-08, 10:08 AM
eddiej
eddiej's Avatar
Default I am in need of some help!
I got in myy 99 ls400 fri. night and it wouldnt start. Or even turn over. But everything seemed to work fine. After about a dozen attempts turning the key, it finally started and the check engine light came on. The car ran fine though. Same thing yesterday morning. Then I got in last night and it started right up and the engine light was off. This morning, started right up. But after about 5 mins of driving the engine light came on. Any idea of what this could be?? Help please!
Old 11-16-08, 10:14 AM
RA40
Super Moderator
RA40's Avatar
Take it in and have the error codes read.
Old 11-16-08, 10:16 AM
eddiej
eddiej's Avatar
I live in corpus christi and theres relly know one that works on a lexus down here. And if they do, they charge a fortune! Can autozone read the error code?
Old 11-16-08, 10:34 AM
trukn1
NELOC Mod
trukn1's Avatar
Your car is OBDII, so autozone can read the code to let you know what is going on. They simply have to plug in the tool and read away.
Old 11-16-08, 12:57 PM
eddiej
eddiej's Avatar
Ok. Went to autozone. Heres the read out.... 1. Catalytic converter defective
2. Engine misfire or running condition 3. Large vacuum leak 4. Engine oil leakage into exhaust - valve guide seals, piston rings. WHAT THE HELL!! It seems like it would be the starter. The car runs JUST FINE! I don't think this read out is correct. Any opinions?
Old 11-16-08, 02:39 PM
Rocan
Rocan's Avatar
chances are it is correct... have those things checked out
Old 11-16-08, 03:41 PM
LiCelsior
Retired
LiCelsior's Avatar
uh....that does NOT sound correct...
Old 11-16-08, 03:47 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
reset ECU.
if it does it again,
go to a shop.
Old 11-16-08, 04:32 PM
eddiej
eddiej's Avatar
When you say reset ecu, do you mean by disconnecting the battery for awhile?
Old 11-16-08, 05:06 PM
trukn1
NELOC Mod
trukn1's Avatar
Unhook battery for 15 minutes and then hook back to reset ecu.
Old 11-18-08, 03:29 PM
eddiej
eddiej's Avatar
Thanks for the help. Its tuesday and I have not had any problems yet!!!!!! Since I had to reset the computer, does that mean it might be going out?
Old 11-18-08, 08:22 PM
trukn1
NELOC Mod
trukn1's Avatar
Just monitor over the next couple of days to see if any of the previous symptoms show up as before. May have just needed to be reset. If they do pop up again,, get a new reading of the codes and then go from there.
karan1193
01-07-15 08:33 PM
gousri
ES - 5th Gen (2007-2012)
04-16-13 07:24 AM
mbrown1782
02-26-13 07:53 PM
Ariyanna
28
01-20-09 04:55 PM
ph0ngster
12-14-05 08:08 AM
Quick Reply: I am in need of some help!
