1999 LS400 suspension question
Old 11-10-08, 10:42 PM
valex
valex's Avatar
Default 1999 LS400 suspension question
A question for you, guys. I have a 1999 LS400 with 96,000 miles all suspension parts are original(except strut rods - changed them like a year ago). I have stock 16" wheels on. When driving on gravel/bumpy/loose surface, I feel sort of a play in the steering wheel. Do you know what that might be? Don`t feel anything on pavement.
Thanks,
Val
Old 11-11-08, 07:57 AM
steveski
steveski's Avatar
Maybe steering rack bushings? I don't recall the OEM tolerance but think it is like 1.5" to 2" play in the steering wheel when engine is turned off and you turn wheel left to right. I have factory manuals and can check tonight for my second gen.
The fact that it is only on loose roads and not on pavement makes me think your steering bushings are fine though.
Old 11-13-08, 01:55 PM
tbilisi79
tbilisi79's Avatar
I also replaced strut rods, but still have some knock from time to time.
I believe its lower Ball joints, or upper ones.
Old 11-19-08, 09:50 PM
valex
valex's Avatar
Default Ball joints on 1999 LS400
Anyone knows how long lower ball joints are supposed to last on 1998 1999 2000 LS400? Any info will be of help.
Old 11-20-08, 12:42 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
pretty sure they last right until they break
Old 11-20-08, 07:51 AM
atoyot
atoyot's Avatar
wow, master of the obvious.
"hey, what kinda gas mileage does the LS400 get?.... well, you can get as many miles as you can until you run out of gas.".......
Old 11-20-08, 12:15 PM
PureDrifter
BahHumBug
it's true though, pretty much none of the suspension components have "designated" lifetimes according to the OEM Repair manuals, just to replace them when they go out of spec.
Old 11-20-08, 10:57 PM
valex
valex's Avatar
I was just trying to see what others experienced. 100K miles? 60K?
Pure, at what mileage were your ball joints replaced? I currently have 97K miles on my 1999 LS.
Old 11-21-08, 12:36 AM
PureDrifter
BahHumBug
im at 117k ish and they're still good
Josette211
13
10-02-15 01:51 AM
DK Audio
17
05-20-14 05:24 AM
gck303
12-30-09 08:00 AM
ur2slow1
01-02-09 09:11 AM
MightyLex
06-14-04 09:55 AM
Quick Reply: 1999 LS400 suspension question
