LS 400 Transmission
Old 11-04-08, 01:51 PM
eyecon7
eyecon7's Avatar
Default LS 400 Transmission
Hey Guys my uncle had a 1990 LS400 which got Rear ended pretty bad the car and motor are really good.. and i found a 1993 LS400 that has a bad Transmission.. can i Swap it the 90 Transmission in... does Anybody kno... thanks Brian....
Old 11-04-08, 07:17 PM
trukn1
NELOC Mod
trukn1's Avatar
Direct swap,, no problem. Still a first gen LS, so will bolt right up.
Old 11-04-08, 07:33 PM
eyecon7
eyecon7's Avatar
cool man...
Old 11-04-08, 07:35 PM
eyecon7
eyecon7's Avatar
thanks.............
Old 11-08-08, 07:22 AM
eyecon7
eyecon7's Avatar
OK Guys i got a couple of questions.. I went ahead and bought the 93 LS... I currently have a 1990... The problem with the 93 is the transmission is shot and AC button doesnt work..so they hard wired the compressor to a switch.. It also Has 300k but the Body is in phenomenal Condition.. the problem with the 1990 was that some one rear ended me and it got totaled... still drives car starts up only 90k on the motor and transmission.. I was thinking about swapping out the 90 motor and transmission to the 93...If this is possible what things do i keep.. and since im taking it out what should be done like timing belt motor mounts ETC to make it new as possible. And some one was telling me the ECU dont match up.. ALL HElP Would be Great. thanks......
Old 11-08-08, 12:59 PM
Scorny
Scorny's Avatar
Your question has been answered already,look up.
Old 11-08-08, 02:43 PM
eyecon7
eyecon7's Avatar
there is a new rack and pinion on the 1993 and a new steering pump on the 1990..... the 1990 has traction control.. i dont think the 1993 has this.....
Old 11-10-08, 06:38 AM
eyecon7
eyecon7's Avatar
Should i go with aftermarket or Oem Motor and transmission mounts?? and where can i get them....
Old 11-11-08, 10:05 PM
flyspyder5
flyspyder5's Avatar
so you decided to be a ********... you wasted your time telling him to search, if you already knew the answer just tell him...
your the reason so many owners of nice cars, and so many people that have tons of information to help other with STAY OFF messageboards.. way to be a ****
Old 11-11-08, 10:15 PM
LiCelsior
Retired
LiCelsior's Avatar
check if the 93 has 2 tps sensors on the throttle body.
i think it might be different ecus.
go for OEM, sewell and carson offer discounts as they are vendors here.
but its true, it has been discussed and seeing that u own a GS what makes u come to the LS forum and disturb our friendly environment with ur negativity? we're just trying to help the new guys by telling them to search so they come up with multiple threads with their situations. so your coming off as a dic|< with your last 2 posts in this forum.
dlcoffin
11-30-23 08:28 AM
LexusFL
17
10-10-22 04:17 AM
AtlasLS400
06-10-14 06:13 PM
LS400life
40
09-14-08 05:40 AM
Quick Reply: LS 400 Transmission
