cleaning idle control valve
Old 10-30-08, 03:31 AM
dedott21
dedott21's Avatar
Unhappy cleaning idle control valve
Do anyone know how to clean the idle control valve?and what cleaner do i need to used!!if i buy this brand new,it cost 650.00!!!!(ouch).i'm new at this!!!!!!!
Old 10-30-08, 05:28 AM
LiCelsior
Retired
LiCelsior's Avatar
i used some throttle body cleaner, sprayed it. used a rag and cleaned up the hole a little bit and then put it back.
Old 10-30-08, 10:02 AM
jcrome04
jcrome04's Avatar
Where is the ICV?
Any pictures of it?
Old 10-30-08, 01:06 PM
LiCelsior
Retired
LiCelsior's Avatar
there was just a recent thread where i put a picture up..
Old 10-30-08, 08:49 PM
dedott21
dedott21's Avatar
thanks,i needed that!!i hope this will work plus i have to get a code reader to get rid of it!!!!
Old 11-03-08, 03:46 PM
jcrome04
jcrome04's Avatar
Hey any link to the other thread? I can't seem to find it...
Probably right under my nose....
Old 11-03-08, 05:50 PM
Anatoliy
Anatoliy's Avatar
try this website: http://www.lexls.com/tutorials/EFI/throttlebody.html
Old 11-04-08, 10:00 AM
jcrome04
jcrome04's Avatar
Hey thanks for the help but I already did the TB clean a while back!
Where is the ICV!!!!!!
Old 11-04-08, 10:47 AM
qewani1
qewani1's Avatar
idle control valve is the black kit where wire is unpluged from it ...as shown in this picture
Old 11-04-08, 11:06 AM
qewani1
qewani1's Avatar
this is what you need to know.
http://www.lexls.com/tutorials/EFI/tps.html
Old 11-05-08, 10:53 AM
jcrome04
jcrome04's Avatar
OOOOOHHHHH SO THE ICV IS THE TPS??????? That's all you needed to say! hahahaha!
Wouldn't it be harmful to spray brake cleaner on a sensitive electronic piece like that?
Old 11-06-08, 08:54 AM
qewani1
qewani1's Avatar
dont spary the TPS. you dont have to clean that. I believe you already cleaned your car' s TB.
Any way is your car still having idle problem?
Old 11-07-08, 07:05 AM
atoyot
atoyot's Avatar
interesting. I may try to turn my IPS (adjust it) this weekend to see if i can bring my idle up some. RIght now at a stop with the AC off, i idle too low for my taste. I'll report back and see if this helped anything.
Old 11-08-08, 08:00 PM
93ls400W
93ls400W's Avatar
Actually the TPS is the TPS. The IACV is not shown in that picture. But if you follow the fat black hose to the right of the TPS it connects to the IACV.
Some people have removed the IACV and sprayed cleaner in it. One actually posted on another fourm that he took it apart to clean it with idle returning to normal range of 650 to 750 rpm.
You need to drain some coolant out if you plan to remove the valve. I would buy a new gasket to replace the old one also.
Old 11-08-08, 08:39 PM
LiCelsior
Retired
LiCelsior's Avatar
iacv is the round thing on this cover..
Quick Reply: cleaning idle control valve
