Can I replace my 15x6.5 rims with 17x8
Old 10-17-08, 08:45 AM
91LS400vgb
91LS400vgb's Avatar
Default Can I replace my 15x6.5 rims with 17x8
I'm thinking of swapping my 1991 LS400's original 15 inch (15x6.5) rims with 17 inch (17x8.0) rims. I will be keeping the tire circumference relatively close (within 3%) to the oem tires. My question is: will the increased rim width from 6.5 inches to 8.0 inches cause any problems with my suspension or safety? Also, does anyone know if I'll have any clearance issues? I appreciate your help.
Old 10-17-08, 10:12 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
depends, what is the offset?
Old 10-17-08, 11:24 AM
91LS400vgb
91LS400vgb's Avatar
Sorry, the offset is +45mm.
Old 10-17-08, 11:33 AM
LiCelsior
Retired
LiCelsior's Avatar
it'll be fine.
Old 10-17-08, 02:49 PM
91LS400vgb
91LS400vgb's Avatar
Thanks, guys. Btw, the original rims are 50mm. I was also wondering if the car can still be aligned using its original specs for toe and camber.
Old 10-17-08, 03:21 PM
Rocan
Rocan's Avatar
it would be a bit off... get it alined by somebody good.
Old 10-17-08, 10:21 PM
PureDrifter
BahHumBug
huh, he's changing the wheels, the Diamter difference is minimized, and did no suspension work, an alignment is not required.
UNLESS your last alignment was a good while ago (>9months)
airchomper
11-04-15 09:47 PM
Rexus300
Wheels, Tires & Brakes Forum
04-02-13 05:13 PM
Femel
RX - 1st Gen (1999-2003)
01-19-10 05:43 PM
decibel
03-09-09 01:23 PM
mike.gani
05-12-07 12:05 AM
Quick Reply: Can I replace my 15x6.5 rims with 17x8
