starter went out on 1990 ls400
Old 09-27-08, 07:34 PM
OGLS400
OGLS400's Avatar
Cool starter went out on 1990 ls400
wow what a job i just started tackling removing the starter , can't believe its under the upper and lower intake manifolds. does any one have any diagrams for this year and model for vacuum diagrams?
Old 09-28-08, 09:09 AM
trukn1
NELOC Mod
trukn1's Avatar
www.lexls.com should help you out quite a bit. Also use the search feature here. This has been written up step by step quite a bit.
Old 10-01-08, 08:28 PM
OGLS400
OGLS400's Avatar
Angry 1990 ls400 starter troubles
so I got the starter in and put everything together fired it up and a fire ball shot out from under the hood, i ran grabbed an extingisher and quickly put it out. not to bad only melted one connector. I pulled it apart again and found number eight fuel injector was leaking. this is what caused the fire, the o ring was cut even though it was brand new from lexus. my question is the fire retardant I sprayed on the motor is everywhere what is the best way to clean it all up?
p.s. after a new o ring put it together and fired right up, no fire issues i just have a white christmas under the hood
Old 10-01-08, 11:18 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
a rag and a few hours
Bylan
06-18-19 04:39 PM
mdrag
12-15-15 03:40 AM
skperformance
06-09-09 10:05 AM
thailegend
04-02-06 10:24 PM
Quick Reply: starter went out on 1990 ls400
