Grinding when braking and accelerating?
Old 09-17-08, 08:22 PM
99svtvenom
99svtvenom's Avatar
Default Grinding when braking and accelerating?
Hey fellas, I've got a 1998 LS400 and have a question. The car has newer brakes on it. When you are moving in reverse and apply pressure to the brakes they grind, then when you put it in drive they feel like they hang up/grind for about 30 feet then the car is fine. When you accelerate quickly there is a bad grind and when you go up a hill the car grinds very badly. The car only has about 75,000 miles on it and has had an easy life. Any ideas to what this grind is?
Old 09-17-08, 08:33 PM
MEANDAFAKA
MEANDAFAKA's Avatar
grind????? like squeak?? or does it sounds like a transmission grind? but i have never heard of this before. show us a clip of what it sounds like, then we might be able to help you out more
Old 09-18-08, 10:14 AM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
Maybe a seized brake caliper?
Old 09-19-08, 09:43 PM
99svtvenom
99svtvenom's Avatar
it is not a squeal. it is a true grind sounds like metal on metal like when a pad is grinding into a caliper. the pads are all good, none of the rotors have grind marks, i have taken everything apart and put it back together twice now and greased all slide pins and see nothing unusual on any of the brakes. Do these transmissions have grinding problems?! it grinds badly when going up hills starting off, and under semi and hard acceleration (worse when vehicle has been running for long periods of time). cruising on the expressway smooth, driving around town smooth, shifts well, drives good. just grinds badly at the points i have stated.
Old 09-20-08, 03:49 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
have you checked the trans fluid, rear end fluid, and the trans/engine/diff mounts?
MarcyproJe
10-10-22 09:08 AM
oscar55773
IS F (2008-2014)
02-11-18 01:49 PM
gabzor
13
03-31-13 08:27 PM
Lexs400
05-11-04 02:45 PM
chaos
Suspension and Brakes
19
12-01-01 12:43 PM
Quick Reply: Grinding when braking and accelerating?
