Oil viscosity change
Old 08-03-08, 12:48 PM
Lzam
Lzam's Avatar
Thumbs up Oil viscosity change
Alright I decided to change my oil grade from 5w-30 to 10w-30 because I could hear the valves ticking and the car didn't tick when I first bought it with 78000 miles on it oh by the way it's a 96 LS 400 even though owners manual says 5w-30 it runs alot quieter now I'm running castrol syntec blend it took about 600 miles to hear the diferrence I have 110,000 miles on her by far best ride for the buck!
Old 08-03-08, 03:58 PM
humanoid
humanoid's Avatar
10w is a tad thicker than the 5w obviously and you probably won't get as good mileage with the 10w, but everything should be fine.
Old 08-03-08, 06:52 PM
jz4203
jz4203's Avatar
I bought my `96 LS400 with 78,000 miles on it. I switched from 5W-30 to 10W-30 (Mobil 1) when I noticed it was burning a little oil. This was about 110,000 miles. This weekend I just turned 200,000 miles. My `98 GS400 has been running on 10W-30 since I bought it at 156,000 miles. Now it's at 230,000. Both cars runs great. So I wouldn't the viscosity change.
Old 08-03-08, 09:41 PM
nthach
nthach's Avatar
I've switched to 5W-30 Pennzoil Platinum over the weekend, I'm noticing no significant difference in engine noise.
Old 08-06-08, 08:03 AM
Daniel N
Daniel N's Avatar
Hi,
I'm currently running 10w 40 Toyota Semi-Synthetic. But after checking my LS 400 manual 10w 30 should be the best oil. I'm a bit confused cause Lexls.com says 5w 30!
Here's a pic of my manual..
91LS400vgb (08-01-22)
Old 08-07-08, 01:05 AM
slamgrayls
slamgrayls's Avatar
Default wassup
how much oil quarts u put in a 91 ls400
Old 08-07-08, 01:09 AM
MEANDAFAKA
MEANDAFAKA's Avatar
6.3 ish quart
Old 08-07-08, 06:03 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
huh, i always got 5 anda bit...tho it has been a while >.>
Old 08-09-08, 05:49 PM
MEANDAFAKA
MEANDAFAKA's Avatar
for real? thats what the lexus book tells me
Old 08-09-08, 06:22 PM
python
python's Avatar
6.3? lmao! u better not be putting that much in it...also u can go to valvelines website, put the year make model and how many miles and it will tell u what oil to put in it
Old 08-09-08, 07:44 PM
atoyot
atoyot's Avatar
Puredrifter, how much oil do you put in for an oil change including the filter on your 00'?
I did my first oil change today and the manual said 6 quarts.
Old 08-13-08, 03:28 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
I do 6 even as well with the filter.
Old 08-15-08, 09:25 AM
rrj_gamz
rrj_gamz's Avatar
Hell, i always thought it was 5w-30 but it depended on the conditions of where you drive (ie hot vs. cold)...But what the hell do I know...
Old 08-20-08, 09:27 PM
Bill Dowd
Bill Dowd's Avatar
Hi Pure Drifter you always said that dino was good for any car but after reading for 3 months on every oil company and what their engineers said about different oils, dino oil ia good and so is synthetic which I use the engineers said that any synthetic which includes toyota cadilac porshe mercedes etc are all the same the 5w30 synthetic which will operate from -45 to +300 or a little higher it will proctect the engine thru the whole range of temps dino oil will go also most the range but not as good.
Old 08-20-08, 10:33 PM
PureDrifter
BahHumBug
huh, i said WHAT?
stop making crap up, i run synthetic in all my cars
rondocap
ES - 5th Gen (2007-2012)
14
07-05-19 03:24 AM
rad-man
10-02-14 10:24 PM
topgun129
12-12-12 09:00 PM
3dog
Maintenance
22
10-17-04 04:39 PM
Straight6
Maintenance
29
05-30-04 01:47 AM
Quick Reply: Oil viscosity change
