90-94 Ls 400 Transmission Is There A Difference
Old 07-28-08, 12:41 PM
BIGBADDAD
BIGBADDAD's Avatar
Default 90-94 Ls 400 Transmission Is There A Difference
Ok,
I have another post about my 94 LS 400 Lunges, The latest problem is the front pump in the transmission is making noise, and I need to replace the trans. My question is...what is the difference between a 1990-1994 transmission. I can't imagine there is one, but I would like your input. I have a friend that has a 1992 trans, in great shape for $300.00, I just want to make sure it will work.
Thank you in advance for any help.
Mark
Old 07-29-08, 07:10 PM
Rocan
Rocan's Avatar
no difference.
Old 07-29-08, 09:17 PM
BIGBADDAD
BIGBADDAD's Avatar
Thank you,
I was starting to think I worded it wrong.
I appreciate your input.
Mark
Old 07-29-08, 10:03 PM
richonenz
richonenz's Avatar
The box itself didn't change til the 5 speed....BUT the ECU controlling it did change , as to if this will make a difference on a change over I don't know , but your early ECU might not speak the same language as the later ECU .
Old 08-01-08, 09:45 AM
BIGBADDAD
BIGBADDAD's Avatar
Thank you,
I actually found a 94 trans so there should be no problem. I am doing the swap today.
Mark
LexusFL
17
10-10-22 04:17 AM
jubin
08-16-17 07:57 PM
Triscutt
08-03-17 09:04 AM
LER97LS400
08-17-11 11:23 AM
Quick Reply: 90-94 Ls 400 Transmission Is There A Difference
