Stock 98-00 wheels, can i use spacers?
Old 07-16-08, 03:30 PM
1995LS400
1995LS400's Avatar
Default Stock 98-00 wheels, can i use spacers?
I have a 95 LS with 98-00 wheels, 245/50/16 Falken tires. I love the setup but would really like to add spacers to "push out" the wheels to the corners a little bit. Do you know where i can purchase some spacers preferably online? And what size in millimeters would be an ok size to use so that the lugs are still holding the wheel firmly?
Old 07-16-08, 03:31 PM
ryanSC300lover
ryanSC300lover's Avatar
Spacers+extended lugs
Old 07-16-08, 06:38 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
15-25mm spacers will get you there if you decide on 25 look for adapters.
Old 07-16-08, 07:38 PM
ryanSC300lover
Originally Posted by PureDrifter
look for adapters.
Old 07-16-08, 09:39 PM
PureDrifter
BahHumBug
already replied to your pm
Old 07-16-08, 10:51 PM
drifto808
drifto808's Avatar
does anyone know the specs of offset on stock lexus wheels??
Old 07-16-08, 11:44 PM
PureDrifter
BahHumBug
+45 for the LS iirc. all OEM lexus wheels have the offset stamped on the inside.
Old 07-17-08, 12:59 AM
skperformance
skperformance's Avatar
You cannot use any spacer that has studs built into it like the kics if you go 15mm or less.
You have to be atleast 25mm to use them other wise you are replacing studs to extended ones. OEM wheels have no space for the studs so they push against the hub.
Oh yah they fit fine i had spacers on all of mine.
krue92
IS F (2008-2014)
09-12-11 06:06 AM
peterwho
02-11-11 04:54 AM
Famou$LS
11-02-09 04:43 AM
Dragnet
11-01-09 02:30 AM
Quick Reply: Stock 98-00 wheels, can i use spacers?
